Lockup speeds?
Old May 25, 2006 | 11:14 PM
2001 White Ws6's Avatar
Default Lockup speeds?
Where do you guys have your lockup speeds set at? The tuner set mine to 45mph so while driving in city it's always unlocked. I don't mind it but there are times when I think about it getting set to a lower speed.
Old May 26, 2006 | 08:58 AM
DannoWS6's Avatar
45 in 3rd
60 in 4th
Old May 26, 2006 | 10:58 AM
Muerte_X's Avatar
Locks up in 4th @ 37mph and 3rd @ 25mph. Stock settings though, haven't messed with them at all.
Old May 26, 2006 | 07:47 PM
vMaster0fPuppets's Avatar
I had my tuner det mine to lock up at 28-35 in 3rd, and 38-45 in 4th, depending on how much throttle is applied. I still get like 16mpg
Old May 27, 2006 | 04:12 PM
FullBoreTA's Avatar
Mine locks up at 45 in 3rd and 45 in 4th. I'm with you, because, most of my driving is in and around town and 35 mph probably would be ideal.
Old May 27, 2006 | 04:15 PM
outkast6991's Avatar
mine is set at 51 in 3rd and 4th.i didn't like the bogging feeling of a lower lock up.but i pay for it at the pump(9-10mpg in town)
Old May 27, 2006 | 04:28 PM
sleeperstyle's Avatar
im 45 in 3rd and 4th, although it lugs the motor a good bit in 4th until about 55-60mph. i drive around in city traffic usually in 3rd. 2.73's btw.
Old May 28, 2006 | 01:16 AM
BlackHawk T/A's Avatar
And probably a hot tranny!
I have stock settings and I like them. 30 in 3rd and 38 in 4th, though i'd like to bump 4th to 45 because its just too much below that and you have no power. I really only lost 1mpg after the converter...
Locking sooner will probably keep the tranny cooler and help with your mileage.
Old May 28, 2006 | 01:26 PM
Kenafin_02TA's Avatar
35 in 3rd, 50 in 4th. That puts me just above 1500rpm when she locks in each gear which is just above the point of her feeling like she's bogging.
Old May 28, 2006 | 02:49 PM
RevGTO's Avatar
Pontiacerator
Exactly - below 1500 is the bog point for the LS1 with converter locked. I set mine to 42 which is just below that with my gears but works well for thoroughfares with a 35 or 40 mph speed limit. I deleted lock-up in 3rd altogether so I can always drop into third when I need the responsiveness.
Old May 28, 2006 | 04:22 PM
Question for you guys about lockup speeds that i've been wondering about:
Normally it will not lock in 3rd unless you are in the "3" selection. In OD it will only lock when it reaches 4th gear. Now when you program it to lock in 3rd in the OD selection (D on Pontiacs) does it unlock quick to go into 4th, then lock again? It doesn't stay locked through the shift does it?
