Can Anyone Help Me
Old May 29, 2006 | 01:50 AM
monkey01's Avatar
Question Can Anyone Help Me
Can Someone Tell Me Why I Have All Forward Gears And No Reverse On A 4l60 E In My Z71
Old May 29, 2006 | 04:39 AM
CRAGER's Avatar
Administrator
I moved your thread here so you can get some better results. You should also try our truck site:
PerformanceTrucks.net Forums
Peace,
Craig.
Old May 29, 2006 | 06:23 AM
FLT's Avatar
FLT
Did this just happen all the sudden or have you just put a shift kit in? Does it go forward in reverse?
Old May 29, 2006 | 06:53 AM
FLT's Avatar
FLT
Ok just read your other two posts. You need a trans due to the fact that you have an inturnal problem and I'm sure it's not pretty. You have one way clutch that has rolled over or a clutch pack that has welded itself together. Please keep us in mind.
Thank you, Vince.
Old May 29, 2006 | 12:57 PM
Rock-On's Avatar
Default hey
You more than likely have a broken sun shell, we see this more times than not.. you'll also lose 2nd and 4th with a broken shell...... sometimes because of the break you'll still have your forward gears, yet loose your reverse. You see the shell is moving in reverse.(this movement allows the sun gear to pull away from the broken shell), but is being held by the 2-4 band in second and fourth. You could also have a burned rev. input or low rev. clutch.... Hope this helps...... Dave
Old May 29, 2006 | 06:18 PM
monkey01's Avatar
one guy said silonoid is that possible since it all happened all of a sudden
Old May 29, 2006 | 06:56 PM
FLT's Avatar
FLT
No not really because a 4l60e trans will have reverse without any power to the trans.
Old May 29, 2006 | 09:43 PM
Jammer's Avatar
LOL, I have only reverse now.... I added MT ET Streets,, on the first run, I got about 25 feet..and whined my way to a parking lot. Once stopped..I couldnt move and it whines/grinds like a whine.. and goes n o where execpt for reverse...It was a long ride home.
Care to trade your forward for my reverse? Maybe we can have some type of sayaynce (sp?)
Old May 30, 2006 | 12:10 AM
1999Z28's Avatar
sounds like a sunshell to me
atelast it's an easy fix
Old May 30, 2006 | 10:20 PM
Jammer's Avatar
Im guessing forward sprag????
