Vig4000????
Old May 10, 2002 | 11:30 PM
Slow Z28's Avatar
Default Vig4000????
well i have the 3200 now, and am looking to go up in stall. this would go through a 4.10 rear/28" e.t. drags. now instead of getting a TP4400 soon, i was thinking of using my free restall to up it to 4000. so what would you think for a bolt on car with the combination? anybody have somethign similar?
Chris
Old May 11, 2002 | 11:38 AM
RyanJ's Avatar
SSU Moderator
Default Re: Vig4000????
matt in IL went 12.0 with that converter and 3.23's. that was like 2 or 3 years ago. with 4.10's it wouldnt be that loose at all.
Old May 11, 2002 | 05:27 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The converter hits HARD, but it's VERY inefficient! I ran it for a short while in my '98 T/A, and the car was pulling 1.53 60' times with a 3,640# raceweight and 3.42:1 gears. However, I gained 38 RWHP by locking the converter up on the dyno! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> If you do try it, I'd have them build you a multi-disk 4000 that you can lockup at the track. It will hit HARD with the 4.10's. Behind the 383, the converter was flashing over 5,000 RPM on the launch! You should see a little less if you're running a heads/cam setup. I would still expect a better ET from a PT4400, though.
__________________
Old May 11, 2002 | 05:47 PM
Slow Z28's Avatar
WOW that's a pretty big gain. guess i'd have to run a lock up switch. although that TP4400 is just so hard to beat..thanks again trevor
Chris
Old May 11, 2002 | 07:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I ran the PI3600 and it was flashing to around 4300. It was super inefficient and I gained 25rwhp on the dyno when I had a 346ci motor with heads and cam.
Old May 12, 2002 | 12:23 AM
Slow Z28's Avatar
if you are talking about Matt98SS, i could have sworn he had a Vig3600 before he did the TH400 swap? any other help with this one?
Old May 13, 2002 | 09:08 AM
Paul F's Avatar
Going with that much stall I would recommend the Yank PT4400 over a Vig4000. The PT4400 will pull much harder on the top end and will run better MPH. Not to mention that it rocks off the line as well. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 13, 2002 | 03:30 PM
98TAauto's Avatar
i wouldnt get the 4000vig.. cause the 3600 is ineffecient enough..
if you want to upgrade just get the 3600 vig <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
11's on nittos isnt to bad <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
