How hard does a high stall tc pull?
The 2.73s are what are actually helping me to hook and hooking is more important than spinning as all of you should know.
. Once i get the car running again and can get a tc i will have a better idea of what i want to do. Right now the car just spins the tires so bad and its pretty much stock. I'm hoping the extra weight will help or 315's will solve the problem.
converter with street tires
This vid I flashed the converter, then floored it. Watch the bobbing heads
Nitto drags and converter
Those vids were with the setup that ran the 12.2 time.
EDIT 1st video reuploaded
2nd gear run (old setup)
. How do you guys get the car to downshift with out it just losing control instantly? Or is the shift tables completely set up differently? here is a video of my car, 2nd gear pull - ~25-105, this will give you an idea of what a 4k stall and 373s will do with your rpms @ wot. the engine is still untuned, however i did have tqm & shift points adjusted. i had bfg drs on at the time so it hooked, however, with street tires it will lay ~20' of rubber from anywhere sub 35 mph. the car has lid, headers, ls6 intake, 4k stall, 373s.
i dropped .55 off of my 1/8 mile on the STOCK (engine & tranny) tune with only the lid, 4k stall, and gears.
