New FLP Level IV in, still having problems..HELP
Ok, tranny was just replaced with a FLP Level IV 4L60E. I put a couple of hundred easy miles on it then started hitting it last night. The shifts are lightning fast, but right after the 1-2 shift it slips until I feather the throttle. I'm going to call Chuck on Tuesday to discuss it, but I thought I'd throw it out here to see what everyone thinks.
The 1-2 shift is great, then the bog hits big time. The RPMs are still there, just no power.
This situation was occurring before the tranny swap, only it happened after the 2-3 shift from a roll. Now it happens after the 1-2 shift from a stop, and after the 2-3 shift from a roll. I have a Yank ST3500 converter and I'm beginning to wonder if the converter isn't screwed.
I trust Chuck's work and personally doubt it is a tranny issue. Can anyone chime in here? I'm really not sure what is up as you can tell by this rambling post.
My mods can be found here: MODS
Thanks,
Denzil
<small>[ May 25, 2002, 02:06 PM: Message edited by: DenzSS ]</small>
I doubt it is the converter unless you didn't flush out the crap from when your old tranny died.
Let us know how it goes.
I'm not sure what it could be besides the converter. It happens after the shift has occurred.
I have two custom pcm's (2000 and 2001) done by John at www.speartech.com that have the these setting changed to +20 degrees and the problem is gone.
Your problem has nothing to do with the Tranny and can be dealt with through the pcm. 2000 and earlier F-Body's do not have this issue.
I hope this helps. Feel free to e-mail me if you have any further questions.
<small>[ May 26, 2002, 03:45 PM: Message edited by: Reboot ]</small>
