Flushed Transmission, 2 days later, 1-2 Problems and P0751 Code
Old Jul 12, 2006 | 11:41 PM
Van5150's Avatar
Default Flushed Transmission, 2 days later, 1-2 Problems and P0751 Code
Jiffy Lubed it - Flushed Tranny. 2 Days later when going to 2nd gear it hangs and revs for maybe 2-3 seconds - then shifts. 2 to 3 and 4 are all fine. 1 day later SES came on. Got scanned and it P0751 - Shift Solenoid A Stuck Off.
Researched this site. No I do not have a stall. I do believe the flushing at 77,000 miles would cause gunk to move to new home - 1-2 Shift Solenoid.
How hard is it to replace / clean. I know its inside the pan toward the back - where? Anyone else do this ?
Old Jul 13, 2006 | 10:23 AM
jimmyblue's Avatar
Moderator
First, make sure Stiffy Lube gave you a full pan of
ATF before you left.
Old Jul 13, 2006 | 10:55 AM
john5632's Avatar
when I put my stall in the next day my fluids was a little low.check your owners manual how to do proper check if your not sure
Old Jul 13, 2006 | 08:43 PM
Van5150's Avatar
Yes, i have checked the obvious., thanks for your help.
Old Jul 13, 2006 | 09:54 PM
LS1NOVA's Avatar
Shift solenoids are on the back of the valve body. There is 2 side by side, and are identical. I would replace both as long as your in there. Just pull the clip and swap em,no need to remove the valve body or anything.
Old Jul 14, 2006 | 01:03 AM
Van5150's Avatar
Thankyou LS1NOVA.
Old Jan 10, 2007 | 10:45 AM
Van5150's Avatar
Well I replaced both Shift Solenoids and it didn't fix it. Yes its been a few months, the car has been sitting there., and now I want to fix it again. It is still having the same issue where even at part throttle it doesnt engage., just holds the 1st gear a bit. 2-3 and 3-4 are all fine.
Any other suggestions?
Old Jan 10, 2007 | 11:06 AM
RegalX's Avatar
sounds like during the flush there may have been some debris that got forced into your valve body and now may be causing some/one of your valves to stick
Old Jan 10, 2007 | 11:35 AM
Van5150's Avatar
Would that throw a code?
Any chance they sell something to flush that out ?
Old Jan 10, 2007 | 02:09 PM
Montec's Avatar
if there is debris stuck in the valve then you may want to pull the valve body and clean it.
