trans cooler
Old Jul 16, 2006 | 04:53 PM
slolt1's Avatar
Default trans cooler
if i bypass the radiater and just run the cooler will it run cooler, i want the car and trans to run at the coolest temps possible.
thanks brad
Old Jul 16, 2006 | 08:14 PM
slowpoke96z28's Avatar
yeah, it will run cooler. some people say too cool. there was a big discussion about this about a year ago if i remember
https://ls1tech.com/forums/automatic-transmission/345185-cooler-trans-temps.html
Old Jul 16, 2006 | 08:25 PM
heres another
https://ls1tech.com/forums/automatic-transmission/344182-would-mixing-up-trans-cooler-lines-cause-not-cool-properly.html
Old Jul 16, 2006 | 08:55 PM
BlackHawk T/A's Avatar
https://ls1tech.com/forums/showthread.php?t=345185
Excellent read. I've been looking for something like that. This stuff gets discussed here all the time.
Old Jul 16, 2006 | 09:18 PM
Boostaholic's Avatar
Running the B&M Cooler & TH400 with no problems
Old Jul 16, 2006 | 09:38 PM
slolt1's Avatar
thanks for the links slow
boost so yours is just strait to the cooler and not running both?
Old Jul 17, 2006 | 12:39 AM
revtime's Avatar
Same here.
My setup came with braided tranny cooler lines and becuase it was in a manual car I just went ahead and ran it the way it was setup for that car. No radiator just to the cooler and back to the tranny.
Its been hotter than hell here lately and my trans temps have not gone above 170.
Old Jul 17, 2006 | 04:59 PM
slolt1's Avatar
the reason for asking is i went from a 6 speed to the th-350, the engine temps never got over 180 but with the auto,wih it running from the radiator and then to the small cooler,temp is running around 210 and did reach 220 i have a 160 stat
i am going to bypass the radiator this weekend and get the b@m cooler and put it dope style insteed of on the back of the radiator and see what happens
Old Jul 17, 2006 | 05:14 PM
violator6090's Avatar
I did not know this that you should bypass the radiator right now i have the cooler and radiator running and my tranny is having problems so i should try bypassing the radiator i guess
Old Jul 17, 2006 | 06:46 PM
slolt1's Avatar
i will let every one know what hapens after i get this done this weekend
Old Jul 18, 2006 | 07:55 PM
please do...ill do the same if it helps
