how much ATF?
A 93-02 Tranny with stock pan and converter hold's 5 Qt's
The converter hold's no additional fluid than that of the 5 Qt's already inside the tranny , How else when you drain the tranny would you remove the aditional 7 Qt's that you claim????
The only other way you would have any additional Qt's is if you had an aftermarket tranny pan and those are only 1-2 Extra Qt's So that would still put you with 5 Less Qt's than the 12 you claim.
I installed a Transgo shift kit in my car which require's completely draining the fluid and took it exactly 5 Qt's to fill the tranny back up
And do you know where the level on the dipstick read after i filled it??? It read FULL!!! And do you know what it still read's FULL!!!
Just because i don't have many post's on this doesnt mean i don't know anything and by the looks of it i know more than you do RICEETER
LMz28 trust me 5 Qt's is all it will take to fill the tranny, As for the ATF rating i would just use what is recommended in your Manual by GM if you buy 12 Qt's be prepared to have 7 extra full Qt's of fluid
sorry LMz28 for dicking up your thread. hope you found out what you needed to know
and thank you other guys for backin me up
2nd like i explained i thought all the fluid came out when the pan was off.. I didnt have the pleasure of being able to remove it and install a t.c. so like i said 5 qt's
3rd I wasn't trying to come off like i knew everything refer to #1
4th I thought i would appologize to you after being corrected and realizing i was wrong .. which i see you didn't deserve so you decide to insult me in return ... So regardless i don't care rightnow of playing who is the tough guy behind the computer So you can suck this dick's dick ok Ricerteer
Pan holds about 4-5 qts, stock converter holds about 7 qts;
If you want to change all 12 (or so) qts, see this...
https://ls1tech.com/forums/showpost....1&postcount=10
