Drivetrain clunk...
Old Sep 3, 2006 | 03:09 PM
JGA's Avatar
JGA
Originally Posted by BlackHawk T/A
Alright I've hung out in here for quite a while but have never been one of the guys posting their problems. Well until now...there is a first time for everything.
I get a real bad clunk when shifting into 3rd gear, and 3rd gear only. 2nd feels good, and 4th feels good. But 3rd clunks hard and it is throttle dependent. The lighter the throttle the harsher it is. If I am on it more, it isn't as noticeable. At WOT, it is not there at all.
It sounds like it is coming from right under me, and sometimes toward the rear, and it feels bad. It's almost like torque management with a little hesistation right during the shift, but my TM is long gone. Again the clunk/hesitation hits right at the 3rd gear shift. It also seems to be worse when driving in 3 as opposed to D.
It sounds like a "pop" and it can't be good. I haven't gone looking for the problem yet but if anyone can throw some ideas my way it would be appreciated...I really hope it isn't the transmission, being the most expensive thing I have done to the car. I also don't remember it doing this when I put the transmission in the car. It has definetely developed over the past few months.
Hi
I had a small clunk under light load into 3rd. It sounded like play in the ring/pinion, but turned out to be a tranny mount. The mount looked fine. I replaced it anyway and problem fixed.
JA
Old Nov 4, 2006 | 02:58 PM
Ralls's Avatar
Sorry to bring this up months later. Did you ever resolve this issue? Cause I'm getting the EXACT symptoms as you. Makes clunk into third with little or no throttle. And driving at high rpms (about 3K) then giving it some gas will do it also. Downsifts are bad into 1st.
However, instead of what you installed.. I put in a tunnel brace mounted torque arm.
This is NOT normal.
Old Nov 4, 2006 | 09:35 PM
BlackHawk T/A's Avatar
I will address the issue in the spring. Got a long 5 months to endure...
Old Nov 5, 2006 | 03:14 PM
RevGTO's Avatar
Pontiacerator
Originally Posted by JGA
I had a small clunk under light load into 3rd. It sounded like play in the ring/pinion, but turned out to be a tranny mount. The mount looked fine. I replaced it anyway and problem fixed. JA
I'm getting the EXACT symptoms as you. Makes clunk into third with little or no throttle. Downsifts are bad into 1st.
I've been posting in this thread because of the same problem. Lately it's started to clunk on downshifts into first. JGA's post is on target because the sound is from the rear and I started thinking I had some play back there. My tranny mount looks good, but I may replace it on the basis of what you've said.
Old Nov 5, 2006 | 05:35 PM
performabuilt's Avatar
LS1Tech Sponsor
Im not totally sure if this is what it is however I have felt what seems like quick drag bump at light throttle after a shift kit install when a large servo is used in both the 4l60e and the 700r4.
In the ones I have dealt with it was actually band/3-4 clutch overlap this happens if the band dosent release before the 3-4 clutch applies for the third gear shift.This was alleviated by enlarging the 3rd accumulator feed hole in the spacer plate,Many kits use a aluminum plug to restrict this feed. Which is fine with most of the stock servos, However due to the decreased release area of the sonax and superior servos and in some cases if the feed is very small the corvette servo you can get this effect
Further explained the 2nd oil applies the servo this side of the servo has less area and the band is applied , Then when the 3-4 clutch comes on during the 3rd shift the same oil thats used to apply it comes in behind the servo and releases it since the area on the back side of the servo is larger,If the oil to there is not quick enough you will have a drag bump feeling particularly at lower throttles.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 5, 2006 | 06:04 PM
jm93camaro's Avatar
I have the same thing in my 4L60. Its on the 2-3 shift. Clunks pretty good at light throttle. Also can notice a clunk back in when decellerating and hit the gas. As far as I know, I haven't put a shift kit in, but, who knows, the previous owner could have.
Old Nov 5, 2006 | 08:05 PM
Ralls's Avatar
Yeh, it mostly happends at shifts. Really annoying cause I go over speed humps and it will clunk when downshifting 1st, then clunk accelerating again when it shifts to 3rd. BTW: I JUST put in a new rubber tranny mount to see if it would fix it, but it didn't. And what is interesting, I only installed a torque arm, and you all did shift kits.. but we are getting similar problems.
Old Nov 5, 2006 | 09:46 PM
This is going to sound extremely simplistic but...is the torque arm torqued completely tight? How about the bushing?
Old Nov 6, 2006 | 08:28 PM
Ralls's Avatar
Definitely.. torqued to spec and checked again after driving it for a while. Bushing are greased and Ok. I have notified UMI about this problem and have had a long discussion about it here: https://ls1tech.com/forums/suspension-brakes/591191-torque-arm-help.html . **Notice in that thread I said everything is ok, but I spoke to soon and realized it still is not resolved (haven't told them yet).**
I have noticed it is temperature related. Its very cold right now.. and untill the car is half way hot, I do not, or barely feel the clunk. It happens once the car is pretty warm.
I am going to re-check the pinion angle tomorrow because I believe it changed with the new tranny mount (tranny not sagging anymore).
Old Nov 9, 2006 | 06:54 PM
Ralls's Avatar
I don't think this will ever get solved...
Old Nov 9, 2006 | 09:22 PM
SPRAYED 01's Avatar
I have the same problem. Ive just learned to live with it. Very light throttle into 3rd and it clunks. 1-2 feels great. Maybe its just normal or if not normal than not damaging to the trans. Im going to try and convince myself that normal and forget about it.
Old Nov 9, 2006 | 09:42 PM
  #32
Ralls's Avatar
Ok, I'll try to get over it then. But it makes no sense that my torque arm instigated the problem. I'll do a trans flush to see if its an oil problem. Other than that, I'll stop posting about it.
Old Nov 9, 2006 | 10:32 PM
  #33
RevGTO's Avatar
Pontiacerator
That's what I've been trying to do with limited success ...
Old Nov 10, 2006 | 04:22 AM
  #34
PBA's Avatar
PBA
If you can get the Trans-Go 700R4 (SK700-Jr-B) instructions, go to page two, step two, and grind the 4 oil exit notches on the steel cover. This will help eliminate this clunk. I have been including these instructions in the 4L60E Trans-Go Performance Shift kit just recently to help eliminate this problem. I can fax you the instructions on this if you desire, just email me a phone number.
