4l60e B&m ratchet installation HELP!!
Old Sep 5, 2006 | 09:08 PM
onebadblackz's Avatar
hook the cable to the tranny up and go I also have a manual valve body in my 4L60E
Old Sep 5, 2006 | 10:32 PM
dhdenney's Avatar
Originally Posted by TJ
the shifter will come with a neutral safety switch and reverse light switch.
the black box on the shifter gets ditched.
youll need to carefully cut and splice some wires to the shifter for your N/S and reverse lights.
Right. If it says 700r4, it'll work on the 4l60e just fine.
Old Sep 5, 2006 | 10:34 PM
dhdenney's Avatar
Originally Posted by Jmax
According to B&Ms website you have to have an aftermarket controller, you're saying that's bull? I'm sorry but I'm a little confused on this deal. I just got my hands on a Megashifter and I hoped it would work, says it works for 700r4 so I figured can't hurt to try it.
The computer will still do all it's stuff, the gear shift in the car just moves the gear selector arm on the side of the transmission. The B&M site probably means that if you put a 4l60e in a non computerized car that you will need an aftermarket controller.
Old Sep 5, 2006 | 11:01 PM
Jmax's Avatar
Yeah that's probably right, I didn't even think of it that way. Thanks guys.
Old Nov 11, 2006 | 02:07 PM
FlightMechYJ's Avatar
Man, am I glad that I read this entire thread. Thanks for the info...
Old Nov 19, 2006 | 11:39 PM
95firehawklt1's Avatar
ive been trying to do this for a long time now, and i just now decided to read the second page and thank god i did. works great.
Old Sep 17, 2007 | 01:57 PM
Bersaglieri's Avatar
I havent got started on mine yet, but would you need the black sheet metal plate if you started with an Auto car? Granted I am going from 4L60E to 4L80E, but just hadnt looked under there yet. Stock shifter isnt manual valve body friendly. Maybe I'll do a write up...
-Dustin-
Old Sep 17, 2007 | 04:37 PM
Bryan @ Speed Inc.'s Avatar
i believe the only manual valve body available for the 4l60e is a forward pattern - TCI sells the valve body.
Old Sep 18, 2007 | 06:29 PM
TJ's Avatar
TJ
all 4l60 manual valve bodies are going to be reverse pattern.
