RAM 980 Installed!
Very nice. 30 miles on it, so I can't rip on it yet but it GRABS. Have to be around 1200 in 1st to get moving, then it hits.
Adjustable master - I'm about an inch off the floor, very low. Feels good, may have the shop readjust Monday after putting a few miles on. I recall reading to adjust it once the tranny is up to temp.
New slave - quick question. With the McLeod adjustable came instructions for taking .800 off the spring on the slave. I've read alot on this board and never saw that; has anyone done that? What does it do, make up for the adjustable? We did it; it's roughly a little less than an inch off the spring.
Other than that the pedal is MUCH heavier; will this go away with miles? 1st gear is hard to get in ( just notchy ) but the other gears feel fine. Reverse I HAVE to hit 5th before putting it in reverse, but then it goes right in.
The best part - everything installed, did the drill out mod, extra 3 holes in the RAM PP ( drill out slightly ) all for $275.00.
If anyone needs a shop near Cleveland, these guys did good. I got to help as well and stayed the whole time. I thought the price was real decent; I had 3 other quotes near $500!!
One last thing. Just started as I was coming home ( last 5 miles of 30 on the clutch ). While clutch is on the floor, and car is in 1st gear but my foot is on the brake, I had slight shudders, almost like chatter. Any ideas?
Thanks!!
Pedal pressure will stay strong. But after you drive it for awhile you will get use to it.
My 980 disc is still doing great. A lot of 6000 dumps on 8.5 inch ET Drags with no problems.
I went to Brunswick Transmission. 330-225-9110. Awesome shop and work. Ask for Bill Williams.
They did me right, and the price ( IMHO ) was awesome.
Now that I have 250 miles on the clutch, it is outstanding.
I did adjust the master the day of this post and that cleared up all problems.
I can't wait to get another 150 miles or so and start ripping to see what it can do.
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
New update:
375 miles, better every minute. Chatter in 1st and reverse if you don't give it enough gas. ESPECIALLY with the T2R; if my wheels are turned and I'm trying to take off and don't give it enuf gas, the car shudders and the T2R groans trying to give traction.
I pretty much have to launch around 1200rpm.
Back to one of my original questions:
"New slave - quick question. With the McLeod adjustable came instructions for taking .800 off the spring on the slave. I've read alot on this board and never saw that; has anyone done that? What does it do, make up for the adjustable? We did it; it's roughly a little less than an inch off the spring."
Anyone?
either email is good now:
bmwpart@Classicautocampus.com
or
SCORPIONRACING@prodigy.net
Car now burns rubber in 4 gears. This is amazing driving a car with a real clutch in it.
On the highway, if I drop it in 3rd at 70mph and nail it, the back end gets loose and when I hit 4th gear it chirps them.
NICE clutch, I recommend it.
