Yank messing up Idle
Old Sep 10, 2006 | 07:22 PM
Christian8A's Avatar
Default Yank messing up Idle
what can that be? the idle goes from 0.5rpm to 1000, goes up and down when I go slow and last time it died almost in the middle of the road
What can that be? or do I need to tune it?
Old Sep 10, 2006 | 07:31 PM
ChevPower's Avatar
If you just replaced your convertor from stock or a heavier convertor to the yank then yes you will need a tune to fix the idle and shift points
Old Sep 10, 2006 | 07:39 PM
2001NBMZ28's Avatar
Start with increasing the in gear idle.
Old Sep 10, 2006 | 09:09 PM
Yea, well I got the car with the yank, I doubt they tunned it. Can anybody explain me a little bit about that? Im new to that, and the guy just said the yank could be used in 3rd gear and is at 3500 rpm
thanx
Old Sep 10, 2006 | 09:25 PM
BlackHawk T/A's Avatar
I think you're confused a bit..."Yank" is a torque converter company. Seems you have a 3500 stall converter. It is also not "used" by yourself, rather it moves the car and without it you would go nowhere. I was rather amused last week when someone brought that up but everyone has to start somewhere.
Idle problems can arise when going to a smaller diameter, lightweight torque converter. Same thing a lightweight flywheel can do to an M6 car (so i've heard). A bump in idle speed and airflow can fix this...talk with a tuner.
Old Sep 10, 2006 | 10:54 PM
buffman's Avatar
^^ even a stock diameter converter with a higher stall can cause idle issues. Easy fix as described, just bump up the in gear idle. Not sure it applies to you LS1 guys, but on an A4 LT1 stepping up the closed tps timing (aka idle) helps smooth it out too.
Old Sep 11, 2006 | 11:36 AM
PonchoFan's Avatar
I have a Yank SS3600 in a '98 TA and before that, a Yank ST3000 and had no idle problems without a tune.
Occasionally, it would stall in reverse-that's it.
I'd look elsewhere.
Old Sep 11, 2006 | 01:10 PM
jimmyblue's Avatar
Moderator
Without the heavy flywheel mass of the chubby stock
converter, any instability in the idle tune is magnified.
You want the idle RPM up a little, the idle airflow up
substantially, probably more idle spark advance and
some attention to the low-RPM mixture (VE table for
the most part, also shaving back on the cold open loop
enrichment).
Even with a stock setup I had some stalling trouble
with a TCI 3000, especially go-brake-go type action.
All pretty easily fixed but it's got nothing to do with
the dyno, it's a parking lot job pretty much.
Old Sep 11, 2006 | 06:31 PM
well my friend I bet is very easy but when I didnt do that before I have no clue how to fix it, could you just send a link or something where is going to tell me how?
thanx
Old Sep 12, 2006 | 03:12 PM
Figz Z28's Avatar
thanx
When u get a tc put in you have to get ur pcm tuned, so that it can idle, and shift right etc.......
Old Sep 12, 2006 | 07:51 PM
You don't "have" to, I haven't yet and have been driving for 8 months on the stock tune. It doesn't have any problems shifting or idling, but the idle does bounce sometimes.
Old Sep 12, 2006 | 08:56 PM
Figz Z28's Avatar
Not all cars are the same and yes u would need to get a tune cuz ur rpms are going to climb alot faster than ur speedo, causing u to hit the rev.
Old Sep 13, 2006 | 04:54 AM
No, not everyone does. Mine does not hit the limiter, because you answered it yourself:
Old Sep 13, 2006 | 06:49 AM
GregWS6&z28's Avatar
Blackhawk is right. just depends on the car
Old Sep 13, 2006 | 08:22 AM
Figz Z28's Avatar
A bump in idle speed and airflow can fix this...talk with a tuner.[/QUOTE]
Just like u said^ Blk Hawk, either way he's going to need a tune!
Old Sep 13, 2006 | 06:30 PM
AK's WS6's Avatar
I get some surge also and it will stall once and a great while, but i'm going to just live with it untill I get some heavy modding done, then i'll go for the full tune.
