Downshifting the TH400
Old Sep 14, 2006 | 09:41 AM
Ima get mines's Avatar
Default Downshifting the TH400
I've never owned a TH400. Is it okay to downshift into 2nd while cruising if you wana take somebody?
Old Sep 14, 2006 | 09:47 AM
12secSS's Avatar
A stock or built one yes, I am not sure about some of the reverse manual valve body ones. What setup are you referring to?
Old Sep 14, 2006 | 10:14 AM
It was already installed in the car but Its a mildly built up one from a 78 suburban I believe. It should be okay then.
Old Sep 14, 2006 | 10:41 AM
jldak318's Avatar
im interested in the same question, but i have a th400 reverse manual valve body.
Old Sep 14, 2006 | 01:55 PM
12secSS's Avatar
You should be OK.
You would have to find out if the trans builder set it up to allow downshifts at speed. This was discussed on a few threads a while ago, I don't recall the specifics. Since ours is a strictly race only Z28, it didn't apply to us. Do a search for TH400 downshifting and it should come up with some good results.
Old Sep 15, 2006 | 01:32 PM
MeanWS6's Avatar
i do it
Old Sep 16, 2006 | 03:25 PM
skipperbisket's Avatar
with a reverse manual setup with a transbrake you shouldn't downshift it, it will eventually cause premature failure.... i think thats what caused my first th400 to kick it so quickly.
Old Sep 16, 2006 | 06:58 PM
jv_Z28's Avatar
Yup, with a reverse manual set up you have to slow down, be at a low rpm to down shift or you can dry up the gear (stop the flow of trans fluid)
Old Sep 16, 2006 | 07:40 PM
sleeperstyle's Avatar
so if you in 3rd cruizing at 60mph on the highway, you can't downshift to 2nd with little to no throttle and then once in 2nd gear nail it? i understand downshifting at signifigant rpms but with no engine braking i don't see how it would cause damage.
what if while you downshifted you kept into the gas just a little bit almost like a rev-match... dunno just asking. i've always wondered about this (downshifting a rmvb setup)
Old Sep 16, 2006 | 07:53 PM
all i know is that i've heard from several reputable trans builders to not do it... so i wont be doing it on my new one
Old Sep 17, 2006 | 01:55 AM
Zombie's Avatar
According to my builder Carl Rossler (goes for his transmissions, don't know about others) it's ok to downshift a RMVB TH400 as long as you are on the gas so the transmission does not free wheel. I downshift to first from a roll sometimes due to my 2.75 gears, but I'm always on the gas. My RMVB th400 was built so that 2nd gear does not freewheel like it normally does as well so I can do 3-2 without issue. I still make sure i'm on the gas though since it makes the transistion smooth.
