t400 shifter options??
Old Sep 21, 2006 | 08:21 AM
Chris Rowe's Avatar
Default t400 shifter options??
Hey guys!!
I recently bought a 98 Z28 that has a turbo 400 with reverse VB and the original owner had the stock shifter modded so that it could be used with the 400. It looks great, but I am thinking of going to an aftermarket shifter.
What are you guys using??
Pics would be great!!
Thanks!!
Old Sep 21, 2006 | 11:55 AM
DanZ28's Avatar
I run the Turbo Action Cheetah Shifter and love it. I have pics of the install, but they're still loaded on the camera. There is a couple threads with shifter pics around.
Dan
Old Sep 21, 2006 | 06:19 PM
SShark's Avatar
This is mine its a HURST.
Old Sep 21, 2006 | 08:20 PM
Chris Rowe's Avatar
SShark that looks good. Do you think there is anything that could be made to cover up where you can see down in the console or would that affect the way that the shifter works??
DanZ28 I have searched and found a few pics, but if you have any links I would love to see them b/c I may have missed them. If you get those pics of your shifter uploaded please let me know.
Thanks for the help guys!!!
Old Sep 22, 2006 | 01:10 AM
DanZ28's Avatar
Smile
Got them off the camera, here you go .
Dan
Old Sep 22, 2006 | 01:16 AM
DanZ28's Avatar
BTW, the coiled cable is for the T-brake and the little box looking thing in the back of the shifter is my wide band guage.
I used the stock A4 shifter console (came out way cleaner than the M6 console I tried first) and cut a dam near perfect shape to fit around the shifter, it looks really clean, no holes or gaps. I also kept my ashtray and cup holder .
Dan
Old Sep 22, 2006 | 10:07 PM
SShark's Avatar
Dan
Hey where are you @ in the Bay? I'm Oakland/Stockton
Old Sep 22, 2006 | 11:36 PM
DanZ28's Avatar
Im in Union City, were neighbors if your in Oakland . We may have crossed paths. Rick from Synergy is a friend of mine as well and did my tuning. Is your car a dark blue color? You have the Vic Jr with the elbow on it right?
Dan
Old Sep 23, 2006 | 07:42 AM
Chris Rowe's Avatar
Nice Dan!!!
That has to be one of the cleanest installs I have seen. How hard was it to trim the console to get it to fit???
Looks right at home in there!!!
Old Sep 23, 2006 | 08:53 AM
ls1408cp's Avatar
b&m ratchet shifter
Old Sep 23, 2006 | 11:20 AM
dame's Avatar
If yoor *** would have came to the damn shootout- you would have already known who Dan is!
Old Sep 23, 2006 | 12:15 PM
SShark's Avatar
Dan
Correct!! That would be me! Damn I used to live in Union City like 7yrs ago. Sucks that I moved = (
Old Sep 23, 2006 | 12:16 PM
SShark's Avatar
Fricken work
Old Sep 23, 2006 | 12:32 PM
White.Lightning's Avatar
Dan
Any installation pics? If not, could you remove the upper center console and show some mounting pictures?
Thanks
Andy
Old Sep 23, 2006 | 02:08 PM
DanZ28's Avatar
Originally Posted by Chris Rowe
Nice Dan!!!
Thanks Chris.
It was actually kind of easy, took me about an hour to cut it then test fit, trim some more, etc. I was actually surprised it turned out so well but I did spend a fair amount of time mounting the shifter properly as well.
Dan
Old Sep 23, 2006 | 02:15 PM
DanZ28's Avatar
Thanks
Andy
Here are some install Pics, not the best quality but you can see what I did .
Old Sep 23, 2006 | 02:30 PM
Thanks for the install pics. Are they threaded bungs welded? Nice idea. Places the shifter at the perfect height while not too far forward to interfere with the HVAC controls.
Any other things needed that were tricky/etc during the install?
Thanks
Andy
Old Sep 23, 2006 | 04:15 PM
DanZ28's Avatar
That is hollow tubing I used and cut to fit. I did tack weld some nuts underneath the plates though so all I had to do was screw the bolt in and not worry about holding the nuts in place.
Nothing to tricky about the install other than finding a good place to run the cable out. I had to do a little cutting on the bigger section of the lower center console to fit around the shifter and cable. You can't see any of it but it had to be done in order for me to move the shifter back that far. The A4 console, as far as cutting the hole, I basically started out by measuring the base of the shiter then i used masking tape to mark the hole I wanted and got it close, then trimmed from there using my right angle air grinder/cutter with a sanding pad on it. I cut the hole in the console where I wanted it first, then I placed and mounted the shifter to fit the console correctly, worked perfect.
Dan
Old Sep 23, 2006 | 04:21 PM
Nice. Thanks for the reply. I am going to swap in a TH400 at some point. I'm doing a lot of research now before I "bite the bullet" and begin modding.
I've never operated a cheetah scs shifter. How does the 1-2-3 shift action work?
Andy
Old Sep 24, 2006 | 03:48 AM
Jimmy P's Avatar
Has anyone put a leather/rubber shift boot over their th400 shifters? I have a Hurst Quarter stick and wondering how it would look with a shift boot covering the opening of the console.
