My Turbo Action Cheetah Shifter! *Pics*
#43
The button can be used for either, shifting it is the easiest of any shifter. No stupid levers you have to push, you just pull back for each gear and there are springs that move the shifter from side to side threw the gates. Down shifting is just as easy just push forward.
#44
So the "gate" is the piece of metal that stops the shifter from going down into 3rd (RMVB). Then the springs move it left, and then you pull down into 3rd?
Downshifting is going back through the gate, and the springs work the same way but in reverse order?
The only downfall I see if you cannot "hide" the shifter under the stock A4 upper console like you can in a quarter stick type shifter. It kind of reminds me of the sport shifters you see in a Lexus IS300 or something- how its gated like that.
![](http://www.wooddash.com/fullimage/IS300%20SHIFT%20KNOB.jpg)
#45
The spring does'nt pull it left for you, you have to pull it left then back to 3rd gear. Pushing it from 3rd to 2nd however will automatically push back over to the next gate (right). See my pics on the first page, it hides just fine.
#51
Have have DanZ28's Cheetah shifter now with the black center console already cutout **complete with cable** If anyone is interested.
$150.00 shipped for what you see in the pictures.
I decided it would be too much hassle to swap out my B&M Pro Stick.
The following users liked this post:
Dragframe (11-16-2019)
