tailhousing keeps breaking
Old Sep 22, 2006 | 05:01 PM
john563's Avatar
Default tailhousing keeps breaking
last wk my tail housing broke while on the dyno.so I ordered a built tranny one from a reputable comp. and on the dyno with the new trans.the same thing happened.The new tranny is fine but for some reason during deceleration something is causing the tailhousing to break.What can this be?alignment issue maybe?
Old Sep 22, 2006 | 05:04 PM
GregWS6&z28's Avatar
what kin d of torque arm do you have? thats very weird that you are breaking it on the dyno.
Old Sep 22, 2006 | 05:22 PM
john563's Avatar
greg its a stock torque arm
Old Sep 22, 2006 | 05:28 PM
jay_99z's Avatar
pinnion angle?
Old Sep 22, 2006 | 06:56 PM
john563's Avatar
everything(suspension)stock .torquearm, pinion angle, lca etc.My new shop is putting it up on the lift to check everthing out right now while we wait for the new tailshaft.Just wanted to know if anyone has experienced this or who has heard of this.Any help in the search process is much appreciated.
thanks
john
Old Sep 22, 2006 | 07:21 PM
Nate_Taufer's Avatar
Maybe driveline flex loading up the torque arm and tailshaft. Try swapping out your motor and tranny mounts for poly ones.
Nate
Old Sep 22, 2006 | 10:02 PM
TJ's Avatar
TJ
tranny mount is #1 cause of it. guy local here busted one on the dyno with a stock torque arm. that lightweight aluminum cant take the stress sometimes.
get it off the tailshaft, and youll be good.
spohn FTW.
Old Sep 23, 2006 | 08:23 AM
john563's Avatar
Ill look into the mounts
Old Sep 23, 2006 | 12:01 PM
pcs9449's Avatar
Do you have a steel or aluminum driveshaft? I have seen this with steel driveshaft equipped cars i.e. 2.73 cars with bolts ons.
Sean
Old Sep 23, 2006 | 02:11 PM
JJB's Avatar
JJB
BMR and others make a torque arm relocation kit used with your stock TA...takes pressure off the tail shaft entirly $250.00
Old Sep 23, 2006 | 07:33 PM
john563's Avatar
I talked to the shop and my tuner this morning and they said the mounts looked fine they believe its in the driveshaft
Old Sep 23, 2006 | 08:49 PM
2xLS1's Avatar
Like already stated, it's almost always cars with steel driveshafts that break the tailshaft housings. Steel driveshafts will break them even with the torque arm mount relocated. Get an aluminum driveshaft.
Old Sep 25, 2006 | 04:29 PM
ABA383's Avatar
I had a Spohn trans mounted TA and an aluminum DS...Not sure what went first, but it ended with a split tailshaft and a DS that looked like it was cut in half by a steak knife on the dyno...I switched to a cross brace mounted Spohn TA and a good 3" steel DS and have had zero issues...Get the TA off of the trans...
--Alan
Old Sep 25, 2006 | 06:05 PM
good post for people to know about the driveshaft. i guess i'm lucky i havent broken any yet with heads and cam, stock TA, and just broke my built trans hardened output shaft
Old Sep 25, 2006 | 09:43 PM
revtime's Avatar
Another vote for getting the TA off the tailshaft. Its one of the best things you can do.
250 bucks aint the cheapest but it will solve all your problems.
Old Sep 25, 2006 | 10:18 PM
s346k's Avatar
check this out.
https://ls1tech.com/forums/showpost....2&postcount=11
Old Sep 26, 2006 | 06:38 PM
john563's Avatar
got a call tonight from my tuner who whent to the shop who is doing the trans.Still waiting for the new tailshaft and had the driveshaft sent out and got new tranny mount and ordered a TA relocation kit.anything else I need to prevent this from happening again?
Old Sep 29, 2006 | 04:05 PM
john563's Avatar
well like I mentioned I got the poly transmout,bmr relocation bracket and had the driveshaft balanced and checked out.I was just wondering why Im just learning about this about the tailshaft.I did not even considered taking the TA off the tailshaft before.I thought you had to make a ton of power before I had to worry about it,and after posting this thread I realized it did not take much to damage the tailshaft,maybe someone put this in the stickies so that more people will look into this more and just get the relocation bracket and poly trans mount before adding more horse power.I know most people want to spend their money on go fast parts,but I guess its better than leaning the hard way and having the tailshaft go out on the track or wors on the street.So I hope this it put in the stickies to help more people out,cuz its not an issue that is brought up alot,but when I posted it I could tell that it was more common than I thought.Thanks for everyones feedback and stories reguarding this issue and like I said I hope that this is made a sticky so others will learn
thanks
john
Old Sep 30, 2006 | 12:50 AM
import slayer's Avatar
the same thing just happend to me. I think I will upgrade and get a much better driveshaft
Old Oct 1, 2006 | 07:50 AM
JL ws-6's Avatar
Race your car!
driveshaft's dont' acause that, the load the tranny sees from the tq arm is what does it lik posted above. Why GM mounted the one part of the rear suspension that sees the most load to the transmission.. is beyond me.
