Burn fluid
Old Oct 8, 2006 | 06:24 PM
ramair21's Avatar
Default Burn fluid
can burn fluid cause flare ups in the 2-3 shift??? I just the tranny rebuilt with a transgo shift kit and a vig. 3500 stall... all other gears are fine. and also im betting a oil leak and burn smell when i drive the car hard?? is somthing wrong
Joey
Old Oct 8, 2006 | 06:54 PM
performabuilt's Avatar
LS1Tech Sponsor
Well burt fluild is not the cause but rather a symptom , I fear you have a burning 3-4 clutch , how does it feel on that shift at light throttle
www.performabuilt.com
Old Oct 13, 2006 | 01:02 AM
ramair21's Avatar
feels fine at normal speed. just when i really get on it seems like the 2-3 shift just flares up? i dont get it?? just had the tranny rebuilt with your stuff. and i know you sell great stuff. the tranny only has about 400miles on it if that.. should be solid!!! Maybe my tune is no good??
Old Oct 13, 2006 | 02:09 AM
LS1Tech Sponsor
You mean you had the transmission built wih parts similar to what we put our transmisions,But theres alot more to building these or really any transmission than just parts , The person doing its is easily just as if not more important,
We dont however sell parts ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 13, 2006 | 02:33 PM
ramair21's Avatar
oh, im sorry... i thought you were probuiltautomatics LOL... so you think my 3-4 clutch is going south??
Old Oct 13, 2006 | 04:10 PM
LS1Tech Sponsor
Yes that would be my thought , so I would be thinking about a rebuild or replacement ,
soon ,
__________________
Call 888-744-6542
Old Oct 14, 2006 | 03:46 AM
ramair21's Avatar
I just had the thing rebuilt?? i just dont get it??
Old Oct 14, 2006 | 10:23 AM
jimmyblue's Avatar
Moderator
Slip in the clutches is what burns fluid inside the trans.
Burning smell, is more likely a little weep hitting the exhaust.
Smell the dipstick (heh) to see if the fluid that's inside, is
burnt. The shift flare might relate more to the fluid circuits
(like, misinstalled, misdrilled shift kit or some internal leak?)
than the fluid but once a friction has glazed you're pretty
well screwed and can flare out even with things working
"right".
Was this problem present before the rebuild, was the 3-4
mentioned part of the rebuild, think about what was touched
before the problem showed up.
Also has anyone been messing with the trans pressure settings?
There are things you can do to screw up WOT shifts if you try
to raise pressure limits above stock and don't fix other
wierdnesses in the tables.
Old Oct 14, 2006 | 07:19 PM
ramair21's Avatar
Before i did the LS1 install i never drove the car. The the owner for the motor and trans messing everyting up in the tranny. So i just had the shift kit put in with clutches. Not sure what they were though. I have messed with the pressure cause i didnt feel like it had one at all. I also have a 3500 stall. I did some other little stuff just for the TC. Do you think my tranny is overheating?? cause its fine when its cold, but when it heats up and does it??? Maybe i should try a different tune see what happens...
