A4 shifting hard
Old Oct 11, 2006 | 08:24 PM
lnuxhakr's Avatar
Default A4 shifting hard
My trans is shifting really hard when I put it into drive. It will almost turn the tires when shifting from 1-2 and jerks slightly when going from 2-3 and almost normal when going from 3-D...I have got 91K on the clock and I just flush it 6 months ago. This problem started this weekend. Where should I begin?
Thanks in advance
Old Oct 12, 2006 | 09:51 AM
lnuxhakr's Avatar
To The El Topo
Old Oct 12, 2006 | 10:34 AM
monicaz28's Avatar
Did you get it tuned, or add a shift kit, or make any similar changes to it recently?
Old Oct 12, 2006 | 11:45 AM
lnuxhakr's Avatar
none whatsoever
Old Oct 12, 2006 | 04:30 PM
performabuilt's Avatar
LS1Tech Sponsor
Hi If the shift timing is correct and thee are no codes stored ,I would service the transmission and replace the pcs(presure control solinoid)
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 13, 2006 | 09:09 AM
lnuxhakr's Avatar
Is that something I can do my self....the pcs..?
