A4 to M6?
Old Oct 14, 2006 | 01:35 PM
Ryanols1on's Avatar
Default A4 to M6?
i dont know if this is the right category.. but id thought id look to the pros to help me.. i was wondering if there is a way to convert my auto 4gear to a manual 6 speed?... or even something like a manual.... is it possible? and how much would it take and what parts?... thanks guys..
Old Oct 15, 2006 | 01:31 AM
Darksol's Avatar
Scroll down further and you'll find the correct forum.
https://ls1tech.com/forums/automatic-transmission/200477-m6-a4-a4-m6-conversion-info.html
Old Oct 15, 2006 | 05:23 AM
Splitz's Avatar
isn't that a sticky somewhere?
Old Oct 15, 2006 | 07:02 AM
darrensls1's Avatar
Here is what it takes:
Originally Posted by B_Pay
I had a shop complete an A4 to M6 swap on my car. Here is a list of the parts needed.
shifter
shifter ****
transmission
bellhousing
transmount
pilot bearing
tranny crossmember
clutch
flywheel
hydraulics
pedal assembly
shift plate
flash pcm
Parts total ~ $4000
Labor ~ $900
I no longer have a need for the Sy3500 TC...PM me if you're interested.
Now "IF" you can find a donor car it gets a lot cheaper. So if someone with a M6 wants to convert to an A4 then you guys just basically swap parts. All you need to pay for then is the labor (if applicable) and maybe the PCM being flashed for a M6.
A lot of people have done this conversion but most feel it's cheaper and easier to just sell the A4 car and buy one with a M6.
Good luck.
Old Oct 15, 2006 | 08:17 AM
8a8mfh's Avatar
Look at the sticky in the manual trans section.
