TCC Solinoid Question?
Old Oct 17, 2006 | 08:39 PM
Pro Mouse's Avatar
Question TCC Solinoid Question?
If a TCC Solinoid is bad,Does it either work or not work?Or Can a TCC Solinoid work half way,inbetween Lock and unlock?Just Curious about how it works....
Thanks!
Old Oct 17, 2006 | 08:49 PM
jimmyblue's Avatar
Moderator
Two TCC controls are in it; the apply solenoid and also
a PWM solenoid valve that needs lit up to give any
pressure to the TCC. You can engage the TCC solenoid
but nothing will happen, if the PWM valve is out of it, or
there is a line pressure problem (like you might find in a
stock tune, 0% commanded line at light cruise can make
for pretty poor grab in a small-clutch converter as even
100% TCC PWM duty, is 100% of not-enough and you slip
under load).
Old Oct 17, 2006 | 09:27 PM
Pro Mouse's Avatar
Interesting,So the TCC and PWM solinoid work together?So one could be ok and one could be bad to make a TC lock up inconsistant
Old Oct 17, 2006 | 10:13 PM
performabuilt's Avatar
LS1Tech Sponsor
yes either couldmake the tcc inconsistant but generally its the pwm solinoid that causes issues
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 18, 2006 | 09:37 PM
Pro Mouse's Avatar
Had my Tranny Shop put a new PWM Solenoid in with the TCC Solenoid ,when I had my new verter installed
Old Oct 18, 2006 | 09:51 PM
LS1Tech Sponsor
Thats ussually the best move to change them togther anyway
__________________
Call 888-744-6542
Old Oct 18, 2006 | 09:57 PM
Pro Mouse's Avatar
Yeah thats what I figured after what you guys said
