shift selanoid
Old Oct 22, 2006 | 08:47 PM
2000SLPZ28's Avatar
Default shift selanoid
where is shift selanoid B in the transmission. my stall wont lock up, it threw the code for that selanoid, and it wont go into overdrive, it would be nice to change it if i knew where it was.
by the way, what does it look like?
thanks for the help.
Old Oct 22, 2006 | 09:01 PM
performabuilt's Avatar
LS1Tech Sponsor
The shift solinoids are the two black ones towards rear of trans , they are identical , i ussually suggest changing them as a pair , question what was the number of the code you got ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 22, 2006 | 09:05 PM
FLT's Avatar
FLT
Here is a picture of a valve body with a vac mod set up. On the bottom of this photo there are two solenoids that look the same. These are the solenoids that you will need to replace. I would replace them both of them at the same time. If you need them go to our web page and send us a email or give us a call. Vince
Old Oct 22, 2006 | 09:06 PM
2000SLPZ28's Avatar
this is what my diablo said
P0756 Shift soleniod B, Performance or stuck off
Old Oct 22, 2006 | 09:16 PM
LS1Tech Sponsor
That is and indicator of a bad solinoid and replacing it would be a good first step but that code is actually set when the solinod is comanded on or off and the manifold sensor doent send the right signal back to the pcm , So though it is likley the solinoid there are a couple other possibilites also ,
stuck shift valve
bad switch in manifold sensor
But again its most likley the solinoid and as i said and vince repeated replace them as a set ,
I wish I know how to post pictures someone needs to show me sometime !
__________________
Call 888-744-6542
Old Oct 22, 2006 | 09:24 PM
2000SLPZ28's Avatar
thanks guys, i really appreaciate the advice and info on this subject. if this fexes the problem i will respond to this thread again
THANKS!!!
2000SLPZ28's Avatar
fixes*
Old Oct 22, 2006 | 09:25 PM
FLT's Avatar
FLT
I did not repeat what you said. I was just busy uploading pictures and you beat me to it!!!LOL By the way guy's the part that you want to replace is spelled solenoid.
Old Oct 22, 2006 | 09:27 PM
2000SLPZ28's Avatar
lol. yea well i got the point across
Old Oct 22, 2006 | 09:34 PM
LS1Tech Sponsor
Yea well im not the best at spelling sometimes and unlike my ms word no spell check here , and I still dont know how to upload pictures but I will figure that out soon , lol
__________________
Call 888-744-6542
Old Oct 22, 2006 | 09:49 PM
Pewterpower's Avatar
If I remeber right, they are about $25 each at the dealer. Just be careful when you pull the clip off them and take them out.......
One is OK, and will come right out, but the other has a spring loaded valve with a check ball in it. I know this cuz I was chasing them down the driveway after they flew out of the valve body.
Old Oct 22, 2006 | 10:53 PM
LS1Tech Sponsor
true lol
__________________
Call 888-744-6542
Old Oct 22, 2006 | 11:24 PM
usd2sing's Avatar
Old Oct 25, 2006 | 06:51 PM
01 B4C's Avatar
Vince, what do these run price wise?
Old Oct 25, 2006 | 07:43 PM
FLT's Avatar
FLT
I'm a little confused to what your question is. Are you asking about the shift solenoids,trans, vac-mod....etc. I believe there is pricing on our web page for all the solenoids w/harness. If you need just the solenoids send us an email or give us a call and I will get you a price.Vince
Old Oct 25, 2006 | 08:32 PM
joecar's Avatar
Originally Posted by performabuilt
...I wish I know how to post pictures someone needs to show me sometime !
Does this help:
6. goto an image hosting site such as imageshack.us or webshots.com;
7. press the "browse" button, browse to your image file, select it, and press OK;
8. press the "host it" or "upload" button;
9. the hosting site displays a link to your image, highlight and copy this link (choose the simplest looking link with no [] tags);
10. when replying to a thread, press the yellow/grey "mountain" picture button and paste in the link into the popup box, press OK;
11. finish typing your reply, and submit the reply.
Old Oct 25, 2006 | 08:44 PM
LS1Tech Sponsor
cool thank you much , its may be a handy trick to know , sometimes its alot easier to show than explain
__________________
Call 888-744-6542
Old Oct 26, 2006 | 02:35 PM
joecar's Avatar
<hijack>
Is that PSA metal instead of plastic...?
</hijack>
Old Oct 26, 2007 | 05:38 PM
MxWickedZ28's Avatar
in that pic which one would be the 2-3 solenoid??
Old Oct 27, 2007 | 08:18 AM
ybaslo1's Avatar
Do you have a converter in your car? If so, if you let the car sit for a while, does the vehicle shift and lock up normal?
