? about trans problem
Old Oct 30, 2006 | 02:08 PM
05gto60's Avatar
Default ? about trans problem
Ive got a 4L65E in my 05 GTO. i now have my second fuddle converter in it, the first one had a washer come apart and went through my whole transmission. Fuddle sent me a new one, and i installed it, but didnt think about flushing the lines at the time. a week or so later i had it flushed and filled, and then changed the filter afterwards. when that washer went through my trans it left aluminum on the bottom of the pan, and each time since that ive checked the fluid there has been aluminum on it. now the new converter isnt locking up. ill be doing 40 on the streets and be at 2K rpms, and 2500 @60 on the highway, and theres aluminum on the bottom of the pan. i think i have been able to get it to lockup on the highway if i move it to 3 and then back to D, but i could be wrong and it doesnt happen every time.
I talked to John today and he thinks its not the converter cause i can get it to lockup, he thinks it may be the trans. Hes still gonna replace the verter, but he thinks its ok cause it can still lockup. my old converter did the same sorta thing, where it wouldnt lockup, but if i went to 3 then D it would.
my question, is he right in thinking that the crap left in my lines caused the solenoid to mess up and make it not lockup? or is it history repeating itself?
either way ive got a new trans from performabuilt on its way, im just looking for some insight
Old Oct 30, 2006 | 09:26 PM
05gto60's Avatar
bump
anyone?
Old Oct 31, 2006 | 12:36 PM
05gto60's Avatar
someones gotta have some input?
Old Nov 5, 2006 | 03:17 PM
05gto60's Avatar
last bump
someone has to have some input??
something else ive noticed is that its in 4th, and i let off the gas the RPMs drop to about 1000, and then come back up. this is what happened with the first verter too when it stoped locking up.
Old Nov 5, 2006 | 04:02 PM
FLT's Avatar
FLT
Doesn't sound good and your saying that it is doing what the first tc did right before it let loose. Did you have the trans gone back though before you installed the second tc? Or just flushed it?
Old Nov 5, 2006 | 05:54 PM
performabuilt's Avatar
LS1Tech Sponsor
More than likley you just have another converter failure particularly if you have metal getting in pan again.
We will be sending you some cooler flush with the trans . be sure and use it and then use air to finish blowing out the lines,this generally will clean everything up very well in there.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 5, 2006 | 06:23 PM
johnjzjz's Avatar
its a shame but you will have to start all over again - send the convertor out and have it checked and cleaned -- take trans to the screws and hose it out including every valve in the body and all the servos, pressure blow out the cooler or i would change it out and put in or make sure all the lines and the fittings are spotless -- OR you will be doing this again -- jz
Old Nov 5, 2006 | 06:27 PM
mattraypharbor's Avatar
good luck man i hate transmissions my front clutch sprag broke the other night i know how it feals.
Old Nov 5, 2006 | 09:30 PM
05gto60's Avatar
i didnt have the trans gone through before installing the other tc (i didnt have the money and fuddle only paid for the tc replacements), it was just flushed. the thing with the first one is that it made a horrible noise in 4th and on the 3-4 shift. this one have made the noise a handfull of times (pwm im guessing), but nothing like the first one. its only acting like it
john- im gonna remove the cooler when i do the trans, then im gonna install a new one later. john is gonna replace the converter, but its not getting installed. performabuilt is sending me a trans/converter combo, so all im gonna have to do is flush the line.
Old Nov 5, 2006 | 11:15 PM
LS1Tech Sponsor
Correct and we are sending you a can of cooler douche to do it with ,
performabuilt
__________________
Call 888-744-6542
Old Nov 5, 2006 | 11:38 PM
05gto60's Avatar
performabuilt
sweet, i didnt know about that till your other post. i was just expecting to clean it with an air line at the shop.
i havent looked around, so no falming, but do most car parts places sell the line cleaner stuff? i might run 2 of them through to make sure theres no crap in the lines or radiator
Old Nov 5, 2006 | 11:51 PM
LS1Tech Sponsor
for that you will have to hit a trans shop or a trans parts supplier
__________________
Call 888-744-6542
