TH400 install
Old Nov 4, 2006 | 06:17 PM
pdouble's Avatar
Default TH400 install
I want to put my TH400 TCI trans with a 4,000 rpm stall into my 2000 WS6 behind a Texas Speed 402/ls2.Its currenlty in my 71 Formula behind a 468 BBC.My questions are as follows.
1-What flywheel will I need?
2-Will the stock 6 speed mount work?.I've heard you can turn it around.
3-Will the driveshaft have to be cut,& if so do most cut & weld the aluminum
shaft or replace the shaft with steel one thats cut & welded?
4-Trans cooler I asume is like any car,locate in a air flowing area.
5-Will the pcm have any problems with the absense of speed sensors & any
switches that are not hooked up?
6-Am I leaving anything out?
Old Nov 4, 2006 | 07:47 PM
blkbird_WS-6's Avatar
https://ls1tech.com/forums/showthrea...400+conversion
Old Nov 5, 2006 | 06:15 AM
pdouble's Avatar
Default Thanks
Well I Certainly Appreciate The Link,that About Says It All.
Thanks
Old Nov 5, 2006 | 03:48 PM
It sure helped me alot. I was scared going into the conversion, but threads like these sure answered alot of questions.
Old Aug 13, 2007 | 10:44 PM
ws6togo's Avatar
good info!!!
Old Aug 14, 2007 | 08:55 PM
Blown 98 Z's Avatar
I recently did the same swap, search through one of my threads. (T-56 to TH-400)
I list most if not all the parts you would need.
