Installed but not tested (Poly Motor Mount)
Old Jul 19, 2002 | 08:59 PM
Ryan K's Avatar
Pathological Modifier
Default Installed but not tested (Poly Motor Mount)
Well, I figured somebody has to be the guinea pig. I bought two Poly motor mounts for an LT1 F-car, the four bolt one PN 3.1116R. These fit in the clamshell perfectly, however they are .3" narrower front to back. With 3 washers they fit perfectly. They are very tight and it will be interesting to see how much vibration they transmit to the chassis. I am waiting on a new TC to get here in the mail before it goes all back together.
I'll keep everyone informed.
Ryan K. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
<small>[ July 19, 2002, 09:01 PM: Message edited by: Ryan Karasek ]</small>
Old Jul 19, 2002 | 11:34 PM
felton316's Avatar
Default Re: Installed but not tested (Poly Motor Mount)
Keep us informed! I've been looking for a set of poly motor mounts for the LS1. Maybe I can finally take of my ghetto torque strap!
Old Oct 29, 2002 | 02:24 PM
Midnight F-117A's Avatar
Update?
Old Oct 29, 2002 | 02:31 PM
Fireball's Avatar
Do a search in ext engine. Both Ryan and myself are running the poly motor mounts now <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 29, 2002 | 05:29 PM
Ryan K's Avatar
Been running them for a while now, They are fantastic. No problems whatsoever. Its a long install with the motor in the car but IMO worth it. If you are pulling the motor out, its a no brainer.
Ryan K.
Old Oct 29, 2002 | 05:39 PM
Dom's Avatar
Dom
What are the pros of this?
Old Oct 30, 2002 | 10:33 AM
Fireball's Avatar
Pros:
Stiffer means of mounting engine. Less engine motion under loading (helps prevent y-pipe banging common with alot of headers) and will transmit more torque to the driveline instead of twisting the engine.
Con:
Can transmit a bit more vibration to the chassis but ALOT less than solid motor mounts.
Old Oct 31, 2002 | 05:52 PM
highgmc's Avatar
wouldn't these poly mounts and the solid mounts out casue false knock?
Old Oct 31, 2002 | 06:29 PM
Ryan K's Avatar
Poly mounts will NOT cause false knock. Solid mounts may.
Ryan K.
