New Tranny question!!
Old Nov 7, 2006 | 07:38 AM
Coonass350's Avatar
Default New Tranny question!!
hey guys i have a '94 Chevrolet Silverado truck..and i do a little racing and i have the stock 4L60-E that came in the truck when i bought it..i was thinking about swapping trannies because i plan on adding alot of performance parts..so far i have 100 shot of nitrous, and a bigger cam to add..and i plan on adding lots more..so i was thinking..would the TH-400 be a good buy? i was just wondering..and also where can i get one for pretty cheap..
Old Nov 7, 2006 | 08:52 AM
performabuilt's Avatar
LS1Tech Sponsor
Well a Hyramatic 400 would be fine if you are no longer interested in the truck being and everyday driver , With the performance modes your planning coupled with the lower gears most people install and higher stall converter,With the 400 you will loose alot of drivability .Personally unless you think your going to cross the 850 plus hp mark .i WOULD JUST GET A WELL BUILT 4L60E,and have both worlds
opinion
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 7, 2006 | 09:07 PM
Coonass350's Avatar
oh okay..i didnt know that..thats why i was asking..im not real fond of trannies so i need all the advice i can get..so the 4l60E is better than the 400 for everyday driving and street racing? correct? and how much would a 4l60E cost without the stall
Old Nov 7, 2006 | 09:13 PM
LS1Tech Sponsor
The trans without a converter is 1420 I have have however listed bellow prices with various stalls also
L60E LT-1 Type used from 1993 to 1997 WITH 5.0 5.7
AND 4.3 ENGINES-with out converter-------$1420.00--------
with 1800 to 2000 stall --$1495------------
with 2300 to 2500 stall--$1655-------------
with 9.5 inch 3000 stall--$1895------------
with 9.5 inch 3500 stall--$1920------------
with 9.5 inch 4000 stall--$1945------------
with 9.5 inch 4500 stall--$1970------------
with 9.5 inch 5000 stall--$2005------------
with 9.5 inch 5500 stall--$2055-------------
__________________
Call 888-744-6542
Old Nov 7, 2006 | 10:00 PM
Coonass350's Avatar
okay..is the 1800-2000 stall for $1495 a good buy? how much tq can it hold? and also would it bolt right back up in place of my original one?
Old Nov 7, 2006 | 10:39 PM
LS1Tech Sponsor
Yes its and excellent buy, though most do preferr a little higher stall
__________________
Call 888-744-6542
Old Nov 7, 2006 | 11:50 PM
PBA's Avatar
PBA
"..i was thinking about swapping trannies because i plan on adding alot of performance parts..so far i have 100 shot of nitrous, and a bigger cam to add..and i plan on adding lots more..so i was thinking.."
The 12" torque converter would not be a good idea here. Depending on how you drive, what the rear end gear ratio is, what the cam duration is at .050" lift, and lobe centerline, etc., would determine the stall. I would go with the 9.5" lockup torque converter, much easier on the gear train when using nitrous & any upgrades in power.
Old Nov 8, 2006 | 04:05 PM
Coonass350's Avatar
okay well what stall would you recommend? my rear end ratio is 3.42 but ill be going to 3.73 or maybe 4.10's but im not sure yet, any advice on the gears also?lol what would be better? 3.73 or 4.10? but anyways the cam is .454/.480 left at .050"..so now tell me what ya think.
Old Nov 9, 2006 | 01:01 AM
PBA's Avatar
PBA
Do you do a lot of freeway driving? or just around town? What is the duration of the cam you are going to use at .050" lift? and the lobe centerline? Is this a daily driver or weekend warrior? I need as much information as you can give me, as this will determine the stall that you will need, and what rear end gear ratio to go with.
Old Nov 9, 2006 | 03:31 PM
Coonass350's Avatar
the specs on the cam are: duration 216/224 and the lift .454/.480 and the lobe separation is 112. i dont do much freeway driving..mostly around town.. i use it as a daily driver but i love to go out on the weekend and race people at a bridge we have marked off a quarter of a mile.. i have a Jet tb spacer and a 40 series flowmaster with no catalytic converter, and i plan on getting another one and running true duals, i also have a ADS superchip, but i plan on adding the 100 shot of nitrous, cam, long tube headers, edelbrock intake manifold, new heads, and then work towards the inside such as new crank, pistons..that kinda stuff..but let me know what kinda stall i would need..thanks
