Noise comming from transmission
Old Nov 8, 2006 | 08:26 PM
c0ncEpT's Avatar
Default Noise comming from transmission
Well ever since I got the car (about 4K ago) I have been hearing this whining noise coming from what I thought was the rear. So I rebuilt it, Installed new bearings, seals and a Tru Trac and I still have this noise. As speed increases the noise gets louder. When I let off the gas its still there but it sounds a little choppy. But the thing that leads me to think it’s not the rear is with I put the car in neutral the noise goes away???? I figure if it’s the rear end it would be there all the time and would have gone away when I rebuilt it anyways. And the sound sounds like its coming from directly under me. Anyone have any idea of whets going on with my car???
Old Nov 9, 2006 | 12:33 PM
c0ncEpT's Avatar
TTT, No one has anything to say on this???
Old Nov 10, 2006 | 01:32 PM
c0ncEpT's Avatar
Wow this sucks....... No one can take any kind of guess at whats wrong with my POS 4L60E!
Old Nov 10, 2006 | 01:45 PM
BlackHawk T/A's Avatar
Yokes, U-Joints, how do they look?
Old Nov 10, 2006 | 01:48 PM
c0ncEpT's Avatar
Last time I changed my oil I still had the noise and they still looked good
Old Nov 10, 2006 | 07:19 PM
FLT's Avatar
FLT
Did you change the pinion bearings? Does the noise come and go if you get on and off the throttle?
Old Nov 10, 2006 | 07:37 PM
Stuarta's Avatar
Remove the drive shaft and check the ujoints.
One or more could be siezed.
Old Nov 10, 2006 | 07:49 PM
performabuilt's Avatar
LS1Tech Sponsor
Placing the car in neutral would not eliminate the rear , When I had my mustang it had a while under acceleration and when you get off and would go away in neutral because theres no load , in my case it was the pinion depth was off just a little rear ends are real tricky just a few fractions off and you have noise ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 10, 2006 | 08:29 PM
FLT's Avatar
FLT
Man I think I just heard an echo!
Old Nov 10, 2006 | 09:00 PM
LS1Tech Sponsor
yep! just worded differently lol Im notorious for repeating my self and others lol
__________________
Call 888-744-6542
Old Nov 10, 2006 | 09:24 PM
FLT's Avatar
FLT
No !
Old Nov 10, 2006 | 11:31 PM
c0ncEpT's Avatar
Ill check the U-Joints again. And yes I changed the pinion bearing cuz thats what went bad with the thing in the 1st place.
Old Nov 10, 2006 | 11:33 PM
c0ncEpT's Avatar
No when I get off the throttle it's still there it just sounds a little choppy. But when I put the car in netural it's dead quiet
Old Nov 11, 2006 | 06:17 AM
FLT's Avatar
FLT
I'm not saying that it's not in the trans but I would pull the diff cover and look for metal on the magnet. Are you running an after market gear? This could be a problem if it is not set up properly. Backlash, pinion depth, and the wear pattern are all very critical as I believe someone else has already stated.
Old Nov 11, 2006 | 10:47 AM
LS1Tech Sponsor
The choppy sound is what makes me think its a differential setup issue , The reason it feels sounds choppy is the load changes up and down when you let off the throttle due to drive train drag through the tranny there is none in neutral so its close to having just the driveshaft alone little to no drag , Though like vince I cant say its definatly not the tranny but Im betting on the differential .
__________________
Call 888-744-6542
Old Nov 11, 2006 | 02:38 PM
jebuzws6's Avatar
I have the exact same problem and everybody is telling me have my rear looked at...so i have to agree with these guys and suggest the rear..
Old Nov 11, 2006 | 11:08 PM
c0ncEpT's Avatar
God damn it! I just put $700 into this freekin rear! If it needs to be replaced again im going to kill my self!
Old Nov 12, 2006 | 01:18 AM
LS1Tech Sponsor
Dont do that ! It will be ok worse come to worse I drove my mustang two years with it whining in the rear and nothing died except a few subwoofers .
"whats that noise, Oh nothing the music isnt loud enought" lol
__________________
Call 888-744-6542
