Parts install
Old Jul 20, 2002 | 10:46 PM
RyebreadZ28's Avatar
Default Parts install
I have a Ram 402/6130 combo, new slave, and McLeod adj. master. Should I install the slave and master before the clutch? Or should I do it all at once?
Can this all be installed in one day? I have wednesdays off, and every other weekend. I was just curious if I could get it all done on a weds. as I'm not sure if shops are open on weekends to resurface my flywheel. If not, I'm sure I can take a sick day <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I've been reading the install university guide over. Any other pointers/tips? Looks fairly straightforward. Any tips on bleeding?
Old Jul 21, 2002 | 02:21 AM
2xLS1's Avatar
Default Re: Parts install
You have to pull the tranny to change the slave, so you should do it all at once. As for whether it can be done in a day, only you know your abilities. It can easily be done in a day. Around here, there are auto parts stores that can resurface flywheels. I've had them resurfaced on Sundays.
Old Jul 21, 2002 | 06:34 AM
Slowhawk's Avatar
LS1Tech Sponsor
It takes me around 6-8 hours,start to finish.I also take my time.The only drawback you might have is if you have the flywheel resurfaced.(takes time)
Old Jul 21, 2002 | 02:05 PM
Thanks for the replies.
I usually take my time too, following everything step by step (Install University baby! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ).
I may just put the master in ahead of time to hopefully prolong the life of my stocker a bit longer, since its been acting kind of funky (pedal is real loose(?) when it sits in the heat for awhile, but still engages ok - no slipping).
Thanks again!
