A4 Problem
Old Nov 18, 2006 | 05:35 PM
2ThouZ28's Avatar
Default A4 Problem
Ok racing some f-in GT an there goes my Tranny mount. 2000 Z28 A4, so i spent half the day trying to get the correct mount then an hour replacing it. Drive down the street an the trans start slipping. 1st shifts at a high RPM, an it will not shift out of second. Pulled diagnostics on it and it threw the codes for o2 Sensor, Both left and right bank, thats fixed. Threw a code also that read Shift Solenoid "A" stuck off....? Need new tranny????????
Old Nov 18, 2006 | 07:04 PM
FLT's Avatar
FLT
Do you have a stall tc that you have put in recently? If you shut your car off and refire it how does the trans work? Or do you still have only 1st and 2nd? Also you might want to edit the f-in word!
Old Nov 18, 2006 | 07:11 PM
2ThouZ28's Avatar
stock, have not put a stall in it yet, thinking new tranny it is slippin extremely bad,k hard to even drive the dam thing
Old Nov 18, 2006 | 07:23 PM
FLT's Avatar
FLT
Are you sure that you only have first and second? It sounds more like you trans is stuck in limp mode do to the solenoid code. This would be more like starting out in third gear. The solenoids that this code is referring to are located in the rear of the valve body and look the same. They can be replaced pretty easy. I do sell them if you want to try this first. Here is a pic of the solenoids.
Old Nov 18, 2006 | 07:41 PM
performabuilt's Avatar
LS1Tech Sponsor
I would try the solenoid first as vince says ,That code sets when the solenoid is commanded on but the ecm does not se the apropriate feedback from the manifold presure switch even though the solenoid is electrically sound, There are a few other things that can cause the code they include a stuck valve and a bad manifold presure switch.
But the solinoid would be the most likley first step , While your in there take a close look at whats in the pan also.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 18, 2006 | 09:19 PM
2ThouZ28's Avatar
i start out in overdrive i get what i assume to be first but i cant put any power on it or it will just slip and can kinda work my way up an it will finally shift at 3500ish then when its in "second" it wont ever shift and around 3000rpm (45mph) it starts to vibrate on the center console alot......
Old Nov 18, 2006 | 09:22 PM
LS1Tech Sponsor
sounds like you very well make have a trans problem mechanical .Pull the pan and let us know whats in there asap ok
__________________
Call 888-744-6542
Old Nov 18, 2006 | 09:49 PM
2ThouZ28's Avatar
i'll do.....
Old Nov 20, 2006 | 05:03 PM
2ThouZ28's Avatar
ok, had to order the on/off solenoid so i still dont have it in. also bought new filter an fluid. drove down the street to see exactly what it was doing but now when you put it in to drive it kicks real hard, and it will hardly move now..... still say to change the solenoid first before?
Old Nov 20, 2006 | 08:38 PM
LS1Tech Sponsor
well it wont hurt to have it on hand but seeing whats in the pan would tell alot
__________________
Call 888-744-6542
Old Nov 21, 2006 | 04:43 PM
2ThouZ28's Avatar
Ok BEFORE I do this solenoid which I plan on doin tonight, I only bought the on/off solenoid cuz that was the only one throwin a code an i ran out of cash while i was there. which of the two solenoids is it? afraid i will b e under there an not know the two apart from each other.
Old Nov 21, 2006 | 06:48 PM
LS1Tech Sponsor
do you know the exact code it threw then i can tell you which
__________________
Call 888-744-6542
Old Nov 21, 2006 | 07:22 PM
FLT's Avatar
FLT
I would try the solenoid on the left of the picture. This solenoid is for the 2-3 shift valve and is the solenoid that is on in second gear. It must shut off to make a 2-3 shift. Vince
Old Nov 21, 2006 | 07:29 PM
2ThouZ28's Avatar
The code was - shift solenoid "a" stuck off. Is it the one to the left in the pic above?
Old Nov 21, 2006 | 07:31 PM
2ThouZ28's Avatar
the pan is off an the filter is off, bought new filter an gaskets duh but waiting for a reply on which one is the on/off solenoid or are they both the same? In the pan, there was a normal amount of "flakes" nothin really it was actualy perty clean besides the tranny fluid.....
Old Nov 21, 2006 | 07:32 PM
LS1Tech Sponsor
checking now
__________________
Call 888-744-6542
Old Nov 21, 2006 | 07:35 PM
LS1Tech Sponsor
the one closest to the drivers side is shift solenoid A
__________________
Call 888-744-6542
Old Nov 21, 2006 | 09:15 PM
FLT's Avatar
FLT
The solenoid on the right of this picture is the A solenoid. However the A solenoid is for the 1-2 shift and not the 2-3 shift. I would replace both solenoids in most cases but this has me puzzeled unless the trans is already hurt. Let us know what you find.
Old Nov 21, 2006 | 10:02 PM
LS1Tech Sponsor
Yes don't leave us hanging after solenoid , Hopefully that will fix it , If not other possibilities do exist for that code I mentioned before.
__________________
Call 888-744-6542
Old Nov 22, 2006 | 09:10 PM
2ThouZ28's Avatar
yea that did not fix it. an would really hate to have to pull the pan again and buy new gaskets an crap lol. ok so whats the next step?
