th400
Old Nov 26, 2006 | 12:20 PM
z28boy's Avatar
Default th400
Do you guys have to run a catch can on a 400 with a normal tranny pan. Mine keeps spiting fluid all over and dont know if there is a clearnce problem with bigger or deeper pans or if i should just get a catch can. If some one can tell me where to get this stuff. That would be great.
Old Nov 26, 2006 | 10:46 PM
FLT's Avatar
FLT
Where is your trans leaking from? I really have never heard of a catch can for a transmission.
Old Nov 27, 2006 | 12:42 AM
performabuilt's Avatar
LS1Tech Sponsor
same here never heard of such a thing , Where is it coming from ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 27, 2006 | 08:39 AM
SLowETz's Avatar
Sounds like it's purging overfill from the vent tube on top?
Never heard of a tranny catch can..... but I'm sure if someone made one.... someone would buy it
Old Nov 27, 2006 | 11:28 PM
revtime's Avatar
Sounds like its overfilled to me.
Old Nov 28, 2006 | 07:06 AM
FLT's Avatar
FLT
This is true it can be overfilled. On th400's they are very picky and must be filled correctly.
Old Nov 28, 2006 | 04:04 PM
z28boy's Avatar
Yea im going to look at it tonight it seems to be coming out the vent tube all over. Seems to only come out at wot.
Old Nov 28, 2006 | 04:50 PM
Yank's Avatar
If you have a bent blade or blades in the converter it will cause the oil to foam at WOT and expand -- allowing it to come out of the vent
also the Buick GN guys use a overflow bag -- they use a ziplock bag tied to the trans with a rubber hose as they like to overfill the 2004r
but check for the correct dip stick also as the fill line is to the gasket pan surface
Old Aug 20, 2011 | 06:00 PM
black01_WS6's Avatar
I have been having the same problem. I have the madman dipstick, and a brand new FTI converter. Any other ideas rather than a overflow system- I dont want to have a bandaid for the problem. I flushed the oil cooler to see if it was clogged, and everything checked out. I really don't want to drop the entire tranny.
Any other ideas?
