TransAxle resassembly guys plz chime in!!!
Old Dec 1, 2006 | 11:59 PM
Gun5's Avatar
Default TransAxle resassembly guys plz chime in!!!
Nissan Maxima 93 Auto junkyard trans... need to put the big brake band back on I cant get it on for **** any ideas? I cant pinch it between the holders? also the band has a few little light light surface cracks I figure it will still work the clutches are good im selling the car for cheap
was wondering where these went (2 washers I assume around some bolt holes or something).. where stuck to the magnet when I opened it
heres the band
thanks, Ryan
Old Dec 2, 2006 | 12:25 AM
2002_Z28_Six_Speed's Avatar
I wouldn't reuse the band at all. Especially the way stock clutch matl is. Not long and it is going to completely crumble away.
Last edited by 2002_Z28_Six_Speed; Dec 2, 2006 at 02:03 AM. Reason: Reword to reflect tone
Old Dec 2, 2006 | 01:11 AM
performabuilt's Avatar
LS1Tech Sponsor
The two gold washers look like the brass sealling washers for the coolant lines,but not sure,
to get he band in loosen the band ajusting pin slide it in a reajust ,
I allways liked doing the nissian trans
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 2, 2006 | 02:35 AM
Gun5's Avatar
ya I was looking at that and i noticed but pins go into the case one has a little hole in it where u could stick a punch and move it alittle i imagine?
ya i think thats what they are i dont get how they got in there
Old Dec 2, 2006 | 10:23 PM
LS1Tech Sponsor
probably easiest to remove the servo from the side , then put band in.By the way bands only like 7 dollars , interestingly enough it work very similair to the 4l60e the band comes on in 2nd and 4th , it also has a 3-4 clutch all the way down in there and if the bands burned you can bet thy are fried , the do the same job with less than half the surface area the 4l60e has , Just some fyi
__________________
Call 888-744-6542
Old Dec 3, 2006 | 02:35 AM
Gun5's Avatar
so i imagine get new band and new clutches
Old Dec 3, 2006 | 10:09 AM
LS1Tech Sponsor
yes and you will probably need to get a lit with the steel plates to since the plates in the 3-4 clutch will most likley be warped, the 3-4 clutch so you will know is the little drum last thing that comes out
__________________
Call 888-744-6542
Old Dec 7, 2006 | 11:04 PM
Gun5's Avatar
got new clutches and band in today.. problem is i put the damn things on the table in order and they fell off so i need the order they go in and I cant get the damn band on either
Old Dec 8, 2006 | 12:46 AM
LS1Tech Sponsor
holler at me tomorrow with your email and ill send you and exploded veiw
__________________
Call 888-744-6542
