Fuddle or Art CArr???
and there is at least one Fuddle on that list. MNRO hasa Fuddle. And if you really want to see fast - check out SR71 and his Fuddle -- 9.3!
As far as the "list," so what? We have only been selling online for a relatively short while. Take a list like that for what it is. A list of people who have seen the post and posted. (P.S. Look more closely; Fuddle is on that list). There simply is not a company out there who will outperform Fuddle.
Also, the idea that numerous people have had their Fuddles take a crap is a huge exaggeration, likely constructed through misinformation. If that many converters took a crap, our warranty would certainly be shortened, or we simply wouldn't make it. Fact is our warranty simply runs circles around the competition.
And the old inefficiency argument - look it up. Look at the people who have compared apples to apples. For example, JimmyBlue has actually documented the comparison. It is a misinformation campaign - always has been.
zspot98, we offer a 2-year warranty, which includes all repairs and restalls. If there is a problem, we will gladly fix it, even when it is not caused by the converter. And if it is a problem with the build of the converter, we will pay for the swap, too. We absolutely stand behind every converter we build.
build and everybody's motor. But 96% at 6000RPM is
pretty near the front of the pack. That was just my
own slip data (nothing I can get my hands on for torque
multiplication @ RPM) and other peoples' same-type logs.
Now, somebody with more motor and who went for a
higher stall than their shiftpoints can use, wouldn't
see such a good number. That's the down side of
getting what you asked for. You're allowed to ask for
things that cost efficiency in application. And it's on
you to put the maker in a 3-dimensional box instead of
the usual two in such a case, when you're making a
one-off combo. I did and I got it. But what I ordered
is not what most track-rompin', give-me-a-hard-hit
types would.
And a converter could just be built inefficient. But that
is all cases, which I don't have any knowledge / data /
involvement with. You post a log of motor and trans
input shaft RPM, I'll show you your (minimum) efficiency
curve. More than that takes a converter dyno. Which
any manufacturer might be well off to visit, to demonstrate
capability against anecdotes and the seats of various
pants. But that's not my business other than curiosity.
I'm not bashing your product, just stating that there have been a lot of unanswered questioned over the past few months. As a current Fuddle customer I look fowad to seeing this post and hope it squashes some of the common mis-conspetions.
Also, this is a pretty amazing statement, considering what's been happening with your company over the past 6 months:
as for the name change, I think he meant status change (it just changed back to sponsor a few minutes ago).
I don't think the others offer two years worth of restalls, I could be wrong.
as for my experience with Fuddle:
my roommate put one in his level 5 FLT powering a regular cab Silverado Z71 (6.0L swap with a little lope to it
). The first one wasn't good, they really missed the mark on the stall speed, it was supposed to be a tight 3200 and it was more of a loose 5500. Fuddle responded quickly and sent a replacement which works flawlessly. This truck sees everything from daily driver use, 4wd burnouts/ launches on the street, mud and off roading to a low 13 second N/A 1/4 mile pass every couple of weekends. In the ~12,000 miles that it's been in the truck it hasn't had an easy day and it's holding up just fine.There was the one issue mentioned above, and like any human run operation mistakes happen - but Fuddle stood up and took care of the issue promptly and courteously, providing the CUSTOMER SERVICE AND PRODUCT WE ALL DESERVE.
