how efficient is the th400 compared to the 4l60?
Old Dec 12, 2006 | 08:32 AM
1320FEVER's Avatar
I went with a TH400 and don't regret it one bit. It feels so good knowing that I don't have to worry about my tranny breaking. Yeah, the dyno numbers aren't that impressive for what I have, but it'll run with any 500+ hp dyno queen all day.
Old Dec 12, 2006 | 05:21 PM
lethal93ta's Avatar
I just ran out and checked mine my old 4l60 was 148 lbs that still has a little fluid in it tho, my th400 was 140 lbs, so there probably really close in weight sence my old trans still has some flid in there, but the parts inside are a lot heavier so it takes more to turn.
Old Dec 14, 2006 | 10:15 AM
TNTaddict's Avatar
great info lethal93ta....thx alot...
Old Dec 14, 2006 | 11:27 AM
gator's 99TA's Avatar
interesting. i would like to see more comparisons.
Old Dec 14, 2006 | 11:50 AM
JL ws-6's Avatar
Race your car!
I dunno what I lost when swapping in the th400 in my car from what it would have made with the M6, because I did a whole motor swap at the same time.. but I can tell you one thing, when I had the M6 in my car, I coudl barely run what the et calcualtors would come up with for a car with my rwhp and weight, now I can beat every calculator I can find by at least a 1/4 second. It's more fun to tell people you have 445 rwhp, then tell them it runs high 10's. Then they look at the car, see it's not really lightened up much.. and then scratch their heads
Is the th400 a little obnoxious on the highway? Yes. Does it run at the track? Yes. Will it break? no. The last 2 mean way more to me then a little extra fuel used.. when I only put about 2000 miles or less on the car every year, I'm not overly concerned.
Old Dec 14, 2006 | 01:58 PM
ls1408cp's Avatar
a local with a mustang had his motor on the engine dyno and did 550fwhp. When he put it in the car with a c4 he only made 350rwhp on the dyno. I need to get more details from him and report back. On hp calculators they say my car makes right at 700fwhp. Which calculators do you guys use?
Old Dec 14, 2006 | 02:55 PM
JL ws-6's Avatar
Race your car!
I have an old school slide rule I use.. I have one saved in my favorites at my house too that's online.. I'll put a lnk to it later.
Old Dec 14, 2006 | 09:45 PM
revtime's Avatar
This says it all.
Old Dec 15, 2006 | 04:47 AM
JL ws-6's Avatar
Race your car!
here.....
http://www.race-cars.net/calculators/et_calculator.html
Old Dec 15, 2006 | 05:56 AM
ls1408cp's Avatar
It says I have 591rwhp but I only made 490rwhp
Old Dec 15, 2006 | 08:45 AM
JL ws-6's Avatar
Race your car!
yeah... I knwo. Run the #'s for my car, 3580 lbs, 123.97 trap speed.. I made 445 at the tires... go figure.
Converters and dyno #'s are like oil and water.. they don't mix well.
Old Dec 15, 2006 | 10:36 AM
  #32
BlackScreaminMachine's Avatar
Internet Mechanic
Me and JL have another friend in CT who runs a 383/th400 setup and when he swapped from a t-56 6speed to a th400 he lost just around 70 rwhp. If I see him tonight i'll confirm it.
Old Dec 15, 2006 | 11:10 AM
  #33
JL ws-6's Avatar
Race your car!
Yes, about 70 rwhp he lost. Sure didn'[t hurt his car at the track at all though did it.
Th400 =
Old Dec 15, 2006 | 03:38 PM
  #34
ls1408cp's Avatar
I think my 408 would dyno around 580 rwhp with a stick
Old Dec 15, 2006 | 04:31 PM
  #35
JL ws-6's Avatar
Race your car!
you're probably right. The kid I knwo that lost 70 hp, he was at 497 I think with the stock in the car, after swapping in the th400 it made 430. his converter is a little tighter then mine, and I made 445 on the same dyno.... tells me it's over 500, how much I have no idea, and really have no intrest in finding out.
Old Dec 15, 2006 | 09:52 PM
  #36
Zombie's Avatar
That calculator says 650 rwhp for me, but my best dyno is 470 rwhp.
Old Dec 15, 2006 | 10:11 PM
  #37
ls1408cp's Avatar
I did it with the numbers in your sig. You woulds have to be 3900lbs. Are you just guessing?
Old Dec 16, 2006 | 06:02 PM
  #38
TNTaddict's Avatar
what about th350 comparing to th400 .....N/A only??
Old Dec 16, 2006 | 06:04 PM
  #39
TNTaddict's Avatar
cuz i have a th400 in my 01 z/28....dose it make any diffs. if i swtich to th350??
Old Dec 17, 2006 | 07:47 AM
  #40
JL ws-6's Avatar
Race your car!
th350 parts are a little lighter, but to build one to take the same power as a th400 will not be cheap. If you already have a th400, I wouldnt' bother unless you are tryignto get every last .1 out of the car.. because realisticially, that's about what you are talking about getting.
BY gettinga custom made converter to your car (not sure what you are running now) you'd stand to probably gain more then swapping to a th350
