loss top end...
Old Dec 13, 2006 | 06:56 PM
01'WS6's Avatar
Default loss top end...
I just did a t56/4l60e swap and i have lost alot of top end. Im running a 3400 stall and 3.73 gears. Anybody have any input on why i would of loss so much top end? Its a rebuilt tranny as well with all fresh parts.
Old Dec 13, 2006 | 07:39 PM
AK's WS6's Avatar
Well, right from the factory a m6 is going to pull harder up top than an a4, just look at mph diffrence in the 1/4mi between the 2. What brand stall? What str?
Old Dec 13, 2006 | 08:24 PM
99Hawk262's Avatar
That's probably all it is....I've had both and I know the M6 felt so much faster even though my A4 is significantly faster than my M6 ever was. On top of that, TC's can affect top end pull. A higher STR converter may not be as efficient up top as it is down low. In my case, with a 2.5 STR the car feels faster up top than it did before but I have no way of testing that theory.
Old Dec 14, 2006 | 04:01 PM
01'WS6's Avatar
I found out today that my epc is not getting any amperage to it at all. Could this cause the tranny to slip in higher rpm's, not shift right, etc.?
Old Dec 14, 2006 | 04:21 PM
BlackHawk T/A's Avatar
In that case...can you check your line pressure? If you aren't getting any I suggest you stop driving it or it will self-destruct, fast.
Old Dec 14, 2006 | 04:28 PM
01'WS6's Avatar
I don't drive it much to begin with cause its not a DD but i just left it at the trans shop to get it fixed. The fluid still looked and smelt normal so hopefully i haven't tore anything up in the short while that i have drove it since it started this problem. They said they were going to put a gauge on it and see where the pressures were at.
Old Dec 15, 2006 | 05:24 AM
MNR-0's Avatar
Don't dyno race with a stalled A4. You are setting yourself up for disappointment. Stalled A4 = ultimate drag race weapon
Old Dec 15, 2006 | 07:29 PM
TonyGXP's Avatar
lock it up on the Dyno (hope you got a Vig) if your TCC can handle it, I know mine Can ...
