Converter question
Old Dec 18, 2006 | 07:31 PM
got V-8?'s Avatar
Default Converter question
What is the difference between an aftermarket converter for a ls1 and lt1? Don't they have the same tranny in them??
Old Dec 18, 2006 | 07:40 PM
1jfuddle's Avatar
The converters are completely different. The transmission uses a different input shaft, and the converter bolt pattern is different also. The LT1 (and LS1 Corvette) used a 298mm while the LS1 used a 300mm design.
Hope it helps.
Old Dec 18, 2006 | 07:50 PM
got V-8?'s Avatar
Hope it helps.
yep that's all i needed. Thanks man
