Need help with shift kit on 4l65e built
Old Dec 19, 2006 | 11:21 PM
FLT's Avatar
FLT
I think that the outer spring would be fine because it is much stiffer than the original. You can always add the inner spring if you want it to shift harder. I believe it alone will work just fine. The seal that is cut is it the rubber one or the teflon one? I don't know if I would use an oring in it's place. If you need the correct seals feel free to shoot me a PM. Vince
EDIT- The little inner spring in an OEM set up is a bumper spring. Or basically only allows the piston to travel so far.
Old Dec 19, 2006 | 11:27 PM
performabuilt's Avatar
LS1Tech Sponsor
well the outer spring does not appear to be stock so since you said you have a super servo , I beleive I would leave out the washers and the center spring though it is actually stock since your goal is considerable softer shifts ,
I do not know that the round oring will work since i have never done that
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 19, 2006 | 11:28 PM
LS1Tech Sponsor
I beleave we were giving the same answer to the same question at the same time lol
__________________
Call 888-744-6542
Old Dec 19, 2006 | 11:34 PM
GMRACER13's Avatar
Yes, we are. Unfortunately I don't have enough posts to play at this time. I'll have to get more posts under my belt before I can roll with the big dogs.
Old Dec 19, 2006 | 11:37 PM
LastBlack02SS's Avatar
Vince, I sent a PM about the o-ring thing. And once again regarding fluid, I've seen a few conflicting things in other posts about synthetic or not. I have a Dexcron III/Macron or whatev certified normal penzoil i believe atf and also have a mobile1 synthetic version. I have 6 qts of both new in bottles. Which to use? An explanation to educate would be appreciated so I understand why rather than just being told. Thank you again.
Old Dec 19, 2006 | 11:44 PM
LS1Tech Sponsor
Well im relativly new to just my actual job is customer service and answering questions in this and several other forums
__________________
Call 888-744-6542
Old Dec 20, 2006 | 12:10 AM
Thank you all for your help.
Old Dec 20, 2006 | 01:51 AM
LS1Tech Sponsor
Thats what Im here for
__________________
Call 888-744-6542
Old Dec 20, 2006 | 05:24 PM
So i finished the work today. Two of the holes in the tranny were stripped so i had to hellacoil them. It worked great and got everything back in. The 1-2 shift is now a ton better and just a hair stiffer than stock.
Now I have another issue though. When i put the car into drive from park or neutral, it does that jarring that the 1st to 2nd shift was doing. To clarify, it was doing this before I did the above mentioned repairs. What could cause this? Any help appreciated.
Lastly, I put 5 full quarts in. The tranny has a deep transmission pan though. Should I put another in or something?
Old Dec 20, 2006 | 11:02 PM
tttttt. anyone?
Old Dec 20, 2006 | 11:24 PM
GMRACER13's Avatar
The forward accum. may have been blocked or might have too stiff of a spring installed? Possibly too much line pressure from the builder putting a turn on the EPC screw? Again, a higher stall convertor would most likely "absorb" most of the harshness in your transmission. Chances are that the unit was built with the intention of installing a higher than stock stall convertor. As for fluid level just check it in park, on level ground, while the engine is running and up to temp. If it's not high enough on the stick add some, if it's a little over it won't hurt it.
Old Dec 20, 2006 | 11:27 PM
  #32
LS1Tech Sponsor
agreed a bad idea but may have happened i would look at that next wish you had said something earlier
__________________
Call 888-744-6542
Old Dec 21, 2006 | 12:28 AM
  #33
Is there anyway I can get a picture labeling the different acumulators and what not so i know what i'm looking at next time I open it?
Old Dec 21, 2006 | 12:31 AM
  #34
LS1Tech Sponsor
I will try and find a pic tomorrow ok
__________________
Call 888-744-6542
