Driveline problem after converter install
Old Dec 20, 2006 | 12:43 PM
ws649er's Avatar
Default Driveline problem after converter install
I had a 3400, 2.1str torque converter installed testerday. i gave it a little gas and it was running incredibly. i noticed a HUGE difference in the way it ran in a postive aspect. then coming home from my girlfriend's house maybe 3-4 hours after i got the car back i heard this really loud CLANK sound come from my transmission. needless to say this scared the **** out of me. when i gave it a little gas it then felt like something was shifting around and I could hear the clank a lot more quietly if i gave it less gas. i put it in neutral then and whenever i hit the brakes fairly hard i could feel something rather heavy moving foward. since I can feel whatever this is moving around even when i'm out of gear, i'm hoping it's just a bolt that fell out or something. I had AAA bring it back up to the shop where I had it done and they're going to look at it tommorrow. the guy there said it might be a loose weight floating around and if he can get it out then the car should run fineagain after that. thank you all for your help.
Old Dec 20, 2006 | 01:09 PM
performabuilt's Avatar
LS1Tech Sponsor
Im not sure this would qualify as a converter problem ? and what kind of weight anyway let everyone know what you figure out
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 20, 2006 | 01:25 PM
ws649er's Avatar
the clanking sound happens right below the middle storage compartment between the driver's/passenger's seat. the weight feels like it could be about the weight of the converter, and you can feel something near the transmission about that weight sliding foward when you hit the brakes, regardless of whether you're in our out of gear. I was afraid to go any faster than ~20 after that and being about 2 miles from my house i drove it just enought to get home. it's hard to say, but after the initial CLUNK in 1st gear it seemed to shift/drive fine into 2nd.
Old Dec 20, 2006 | 02:21 PM
GT Griller's Avatar
Well the being that the car moves then we know its not come unbolted from the flywheel, also since its still bolted then it shouldnt be sliding back and forward.
Old Dec 20, 2006 | 02:55 PM
98BlackTransAm's Avatar
so do you have any hypothetical diagnosis?
Old Dec 20, 2006 | 03:09 PM
zspot98's Avatar
Loose torque arm mount? How's that for a hypothetical diagnosis?
Old Dec 20, 2006 | 03:19 PM
LS1Tech Sponsor
That would be and excellent guess i would look there too
__________________
Call 888-744-6542
Old Dec 20, 2006 | 03:38 PM
Joel_SS's Avatar
Yep make sure the bolted the TQ arm back up.
Old Dec 20, 2006 | 04:53 PM
cablebandit's Avatar
or broken trq arm mount
Old Dec 20, 2006 | 05:28 PM
jay_99z's Avatar
May be bolted....but bolts could be loose. Car will still move but will make all kinds of noise with a loose convetrer bolt. I've had one back out on me...
Or your converter took a ****.
Old Dec 20, 2006 | 06:31 PM
GT Griller's Avatar
Even if 1 bolt backed out the only way the car will move is if the converter is attached to the flywheel, for it to stay attached then something has to be holding it to the flywheel atleast 1 bolt....that one bolt shouldnt let the torque converter move back and forward, because if it did then the car wouldnt move.....There might be a loose bolt, but he is describing that the TC is moving as if it were sliding on the shaft.
Old Dec 20, 2006 | 06:56 PM
TonyGXP's Avatar
do the trans mounts break in the newer Fbodys like the old ones? or maybe they didn't bolt it back up?
Old Dec 20, 2006 | 07:08 PM
GT Griller's Avatar
Ive broken the stock one and a energy suspension one aswell....but thats more of a clunck sound that u can feel thru the shifter, but it never hurts to check.
Old Dec 20, 2006 | 07:09 PM
The1N_only's Avatar
it doesnt take much to break a tranny mount
Old Dec 20, 2006 | 09:14 PM
jay_99z's Avatar
Hell anything's possible. Maybe it's not a bolt. But......it doesn't take much movement at a couple thousand RPM's to make some god awful noise.
Hopefully whatever it is can be fixed easy and cheap. Good luck.
Old Dec 20, 2006 | 10:38 PM
MNR-0's Avatar
Default correct title?
So is this really a "fuddle converter problem" or is it a "driveline problem" given you really don't know what the problem is? Its thread titles like this that do wonders for perception.
Let us know how it goes - Im sure we are all keen to know what caused the bang.
Old Dec 20, 2006 | 10:56 PM
LS1Tech Sponsor
i do not think its a converter problem
__________________
Call 888-744-6542
Old Dec 20, 2006 | 11:05 PM
GT Griller's Avatar
me neither
Old Dec 21, 2006 | 12:22 AM
ws649er's Avatar
i'm sorry to have labeled the thread that,, i meant to add a question mark to the title ("fuddle converter problem?") and if the mods would be able to edit that I'd appreciate it. i'm glad to hear that you don't think it's the converter itself because the people at fuddle have shown me great customer service and while i'm sure I'd be able to get them to send me another converter if this one's bad I don't want them to have to pay for that. if it's not just a loose bolt and the tq arm or tq arm mount are broken do you know how much that might cost me to replace?
greatly appreciated,, I hope to God it's as simple as a loose or missing bolt.
Old Dec 21, 2006 | 12:23 AM
LS1Tech Sponsor
those items would inexpensive to deal with and as for the thread you can do either of two things edit it or delete the entire thread FYI 'But i would chack and make sure its bolted up first
__________________
Call 888-744-6542
