Converters... You get what you pay for
#41
I have an M6 and only visit the A4 forum to keep up on the workings and dealings of 'slushboxes'
I thought I used to see a lot of posts about how great the Fuddle converters were.
What happened?
It sounded like he knew what he was talking about...
What happened?
#42
Yank goes thru many tests on all brands of converters like this one that shows the time it takes to make a WOT run on the Dyno in 3th gear from a dead stop so we can deliver a great product that gets the job done.
test takes into account converter weight, and stall speed
you can see the lighter and smaller converters get there quicker
Note: low converter efficency will also help to quicken the spool up time so other test data is needed help round out all findings
https://ls1tech.com/forums/attachmen...chmentid=35191
#43
"damn that was a quick slushbox!"
What happened?
What happened?
My understanding now is that John is better, the orders have been and are being filled again and customer service is back on the rise. But the quality of the converters is still being debated.
But you got an M6 so you can just
J/K
#44
looks like a fuddel due to the way the mounts are welded on the converter.im still debating on this new car i have what to go with. it will be yank or vig.
my last car i had problems with a vig so i dont know. the fuddel i had was crap. so i guess it only leaves me on real option. yank. i have only know of one problem with yanks. my buddy had one that had a pin hole in the paremiter weld around the hub. it would spray fluid but i belive mike at yank took care of it and it was flawless
#45
Originally Posted by trigger1
Billet just simply means the part was machined from a large block of material.
And??? The point I'm trying to make is that the front covers of quality stall convertors are custom made in order to provide enough flat apply surface area for a wider lock-up clutch. They are not factory 4-cyl front covers which only have enough flat surface area for a tiny 4-cyl lock-up clutch. ALL quality stall convertors with lock up use a "billet" front cover so I'm not exactly sure what the point is that you are trying to make.
#46
#47
I guess there's good and bad in all........ but the tank I have in my car has been in since early 2000 with no problems whats so ever..........the tranny now has been gone but the last time I put a new tranny in I went with the bandwagon on a budget tc........one week later it came out and the refurbished yank went back in and will stay in.But my yank does have the six bolt lugs on it and I do belive that does help when you spray the car not near as much flex...........
#49
all this talk about fuddle has got me worried......i just got a 3400 fuddle hp street converter and i'm about to put it in tomorrow and on top of all that i'm sprayin a 125 shot.....i'll keep everyone posted on how things go with it.....i got it used out of a wrecked t/a with 500 miles on it...
#52
Pontiacerator
If you have been on this forum long enough, you will know that catastrophic failures have happened with every popular brand of aftermarket LSx converter. To the guy it happens to, that converter line becomes the worst in the world, and if he has no problems with his replacement, it is the best. The more money he pays for the replacement, the more confidence he has in it - "you get what you pay for."
There is always some risk in installing an aftermarket TC. Knowing well how a particular converter is built - as GMracer points out - allows one to assess that risk and make an informed decision by balancing risk vs. price.
My reading of this forum would indicate that Vig has the lowest incidence of problems, followed by Yank, then TCI (especially lock-up clutch failures) and then Fuddle, Midwest, etc.
#53
see thats funny to me...my 3 precision converters...i would blow right thru them....midwest converter is what Mike Brown has and he is running mid 8s in a turbo DR car....my fuddle is the only converter i have had that would hold my car. I agree, the converter pictured is junk. The first converter I ever had was a yank TT3000...came on a used built tranny i bought for my 00TA. Before installing, i had it cut open locally to make sure it was clean and the guy said it was junk and that it cost way too much for what was in it. Do i think all yanks are junk? Obviously not but i do think they have all had their moments
#54
My point was in your useage you used the term billet as if to imply added strength which is incrorrect. Strength is derived from material / processing / treatment.
#55
Retired Street Racer
Originally Posted by Quickin
For the record, my brand new (4 months old) VIG 3700 exploded while driving steady at 45 mph and destroyed my ALSO 4 month old FLP IV tranny......so it doesn't matter who you go with really.....but you might as well go with the top people to better your chances.
#57
Billet parts built by YANK are much stronger than the stock reworked stamped parts
The single plate clutch we use is made of BILLET steel and extra thick to stop any flex of the clutch surfaces
a flat surface will give the max holding power that is also why we use a billet cover in addition.
the structure of the mating surface must meet many demands
It must stay flat under load (engine torque twisting the mounting lugs on the cover)
it must stay flat as the internal pressure changes
it must handle heat with out warping
and it must have the correct friction specs for the need.
other items are, it must not deform during the welding process and have ability to trap and absorb some debris without damaging the clutch surface.
also other internal parts like turbine hub and stator parts & impeller hub ar billet
Billet is better (the truth)
#58
#59
#60
Moderator
Everybody has their own personal preferences on products and some of these decisions are made based on facts and some on feelings.
When it comes to converters or other parts I really think you should only post what you have FIRST HAND KNOWLEDGE of, not things you have heard.
With that being said, I can tell (listed in order from first owned) you that the Precisions Industries Vigilante (2800 and 3200), Yank 4000, and TCI 4000 have all been outstanding performers. Did I have problems with any of them? Yes I did, but they were all taken of.
John
John
