Yank stall, TCI flexplate
Old Dec 30, 2006 | 01:04 AM
Cop Car's Avatar
Default Yank stall, TCI flexplate
so i got my yank, and i have my tci flexplate. the flexplate came with a spacer to fit in the crank, i test fit it as best i could and it dosent look like i can use the spacer with the yank stall. so i put it together without the spacer, is this ok?
Old Dec 30, 2006 | 10:31 AM
Yank's Avatar
as long as the pilot is in the crank you will be fine
Yank puts the correct pilot on the converter for the engine /trans combo
make shure the bolts are correct and not to long without the spacer for the crank
Old Dec 30, 2006 | 03:38 PM
DanZ28's Avatar
You shouldn't need the spacer. Like Yank said, as long as the TC pilot protrudes into the crank, your good.
Dan
Old Dec 30, 2006 | 07:05 PM
Cop Car's Avatar
the bolts that were sent in the stall were really short. i ended up having to get some diffrent bolts, but then i had to make sure that they werent too long.
may i ask yank why they make them blind holes, rather than tap all the way through? is it for strength? becuase it would be cheaper just to make the threads go through rather than blind holes, just wondering..
Old May 28, 2007 | 11:06 PM
SuperC1's Avatar
Good question, because mine will not torque down, they seem too short to grab enough threads. My brand new yank converter acts like the bolts are stripped.
Old May 29, 2007 | 11:30 AM
Bryan @ Speed Inc.'s Avatar
which bolts did you guys use???
i'm also going with a yank verter with a TCI flexplate, i have ARP converter bolts, but they are short.... i don't know yet if they are too short or not.
Old May 29, 2007 | 03:30 PM
anyone??? Yank???
Old May 29, 2007 | 03:59 PM
SuperC1's Avatar
Originally Posted by Cop Car
the bolts that were sent in the stall were really short. i ended up having to get some diffrent bolts, but then i had to make sure that they werent too long..
What size bolts did you go with?
Old May 30, 2007 | 10:00 AM
RICEETER's Avatar
the arp's are too short. just go to the local hardware store and pic up some (GRADE 8) 12mm x 1.5 x 20mm hex head bolts for like $1 each. they work perfect. they measure 20mm (3/4 in) thread length. the head is not included in the advertised length
Old May 30, 2007 | 11:12 AM
dude you rock! ...providing the info is correct. lol
Old May 30, 2007 | 01:09 PM
RICEETER's Avatar
worked on my car. with a yank stall and tci flexplate
Old May 30, 2007 | 10:28 PM
SuperC1's Avatar
Grade 8 for metric bolts is different than standard. The metric equivilant to grade 8 should say 10.9 on the head of the bolt. Your bolt is more than likely a class 8.8 metric which would be more like a grade 5 bolt, which is not quite as strong as a grade 8.
Old May 31, 2007 | 10:00 AM
RICEETER's Avatar
MY BOLTS are grade 8 (or equivalent). they do say 10.9 on the head (which is more than likely a grade 8). thanks for clarifying that for him though. i left that part out. grade 8 and 10.9 is kinda like walking in a saying i need a metric bolt 3/4 inch long rather than 20mm. they catch your drift
Old May 31, 2007 | 12:29 PM
SuperC1's Avatar
What hardware store did you find 10.9 metric bolts? Most of them (Ace, True Value, Home Depot and Lowes) only carry the 8.8 unless you special order them.
Old May 31, 2007 | 01:55 PM
i'd be buying them from ACE since it's the closest hardware store.............. good question.
Old Jun 1, 2007 | 08:14 AM
RICEETER's Avatar
i got them from Ace. they had about a handful in stock. they are a bronze color fwiw
Old Jun 1, 2007 | 09:38 AM
i called two ace's in my area - they didn't have them, also called home depot... they didn't have them. i think i'm going to use either ARP flywheel bolts, or pressure plate bolts. the flywheel bolts are about 3/4 of an inch long thread... the pressure plate bolts are an inch...
i'd like to have as much thread in the converter as possible - with the TCI flexplate and a Yank converter - is an inch long thread too much???
Old Jun 1, 2007 | 10:24 AM
RICEETER's Avatar
honestly, i think they'd work but i'd hate to tell you to go buy em and then them not work (it'd be cuttin it close). ARP just charges so damn much for that ****. you could prolly order some through ACE and come out alot cheaper and have them in your hands just as fast or faster than if you order ARP's
Old Jun 1, 2007 | 10:32 AM
i'm not ordering the ARP's... picking them up locally so i'll have them today.
Old Jun 1, 2007 | 06:17 PM
transam69230's Avatar
ARPs wont work with a TCI flexplate, i know i order arps then a flexplate and i was kicking my seld after i had spent the whole 11 dollars for the ARPs
