which 4l80 flexplate?
Old Feb 12, 2007 | 05:59 PM
  #41
MIGHTYMOUSE's Avatar
Originally Posted by NA$TY-TA
So that means the Trans is in??? Pic's man pic's.... you know better then that....
don't have any install pics
these two are the clearance for the main wiring plug and the trans line
http://www.richmondperformancemuscle...ture18431.aspx
http://www.richmondperformancemuscle...ture18432.aspx
these are my shifter situation
http://www.richmondperformancemuscle...ture18434.aspx
http://www.richmondperformancemuscle...ture18436.aspx
these are the flexplate installed and the trans not installed
http://www.richmondperformancemuscle...ture17900.aspx
http://www.richmondperformancemuscle...ture17224.aspx
Old Feb 12, 2007 | 07:16 PM
  #42
NA$TY-TA's Avatar
David if ya dont mind..... how much was your core for the trans and what did he do???
parts used????
Old Feb 12, 2007 | 07:58 PM
  #43
JMBLOWNWS6's Avatar
Here is mine. Your going in exactly the right direction on the shifter setup. I just welded a perfect plate to cover the hole. Then I just drilled a hole my reverse lights and TC lockup for street use. Here is a kinda far away pic. My car is at my shop waiting on a new tensioner.
Here are some SHITTY pics of the converter and trans. I took the cover off to show you. These are old and sorry I took so long. Your looks really good MM. Good luck with it.
Fixed my leaky valve cover allready Made a mess!
Old Feb 12, 2007 | 08:49 PM
  #44
T/A KID's Avatar
My 4L80E from Transformance came in today
Old Feb 12, 2007 | 10:08 PM
  #45
forgot this pic, as good as it looks, ive allready cut off the quicksilver handle in favor of a factory 6 speed handle.. no pics of that yet
nasty, i have the moroso pan, a rossler trans brake, and the upgraded drum and input shaft, i didnt have a core charge, and the price was extremely reasonable from transformance
oh and i run a hughes dipstick set up cuz it was the cheapest available and i bent the top over with a torch to clear the cowl.
Old Feb 13, 2007 | 06:23 AM
  #46
NA$TY-TA's Avatar
PM me what ya got into to alltogeather please.....$$ wise.
Thanks
Kyle
Old Feb 13, 2007 | 06:55 AM
  #47
Frost's Avatar
Looks great Dave!! I hope my shifter setup turns out anywhere near that nice.
Old Feb 13, 2007 | 11:54 AM
  #48
i have reasonable rates
Old Feb 13, 2007 | 02:26 PM
  #49
NA$TY-TA's Avatar
Sweet.. got the PM Dave.
I really cant wait to see what your car does.... Im sure from there that will make up my mind
Kyle
Old Feb 13, 2007 | 05:33 PM
  #50
JMBLOWNWS6's Avatar
Hey monkeys Im getting a turbo kit so I can try to keep up!
Old Feb 28, 2011 | 11:00 AM
  #51
Vetal's Avatar
I'm not sure you remember after 4 years, but how did you get 4L80 converter to work with 4L60 flexplate? I read something about that 4L80 converters are not centered on 4L60 flex, need some kind of spacers...
Old Feb 28, 2011 | 11:25 AM
  #52
slow67's Avatar
Gingervitis Addict
The converter company should be able to do this (if you tell them when you order it).
Old Feb 28, 2011 | 11:41 AM
  #53
Vetal's Avatar
So, I need to tell them I want converter to work with 4L60E flexplate?
P.S. slow67 you are answering so many questions I have, thanks a lot BTW you're one of the reasons I ended up ordering 4L80 from Jake instead of building it locally
Old Feb 28, 2011 | 12:14 PM
  #54
slow67's Avatar
Gingervitis Addict
No problem!
Yes, tell the converter company you would like to use a 4L60E flexplate setup.
Old Feb 28, 2011 | 06:29 PM
  #55
Vetal's Avatar
But what are differences in detail between 60 and 80 flexplates and converters?
