removing torque managment?
Old Jan 5, 2007 | 07:40 PM
Magnet's Avatar
Default removing torque managment?
i heard this can hurt the tranny and make it not last as long? is that true? i want my tranny to last as long as possible so, if this is true i will steer clear....
Old Jan 5, 2007 | 08:17 PM
chrs1313's Avatar
leave it in i still got mine and ran a good time...it takes out timing between the shifts so it is easier on the trans...it is so fast that it will maybe help you like half a tenth in the 1/4...i guess the question is why do you wanna remove it
Old Jan 5, 2007 | 08:24 PM
Magnet's Avatar
well obviously i would be removing it to cut time off my ET. But if it is truely going to be hard on my tranny i would rather leave it...
Old Jan 5, 2007 | 10:17 PM
mullenh's Avatar
i took mine out and it is fun but it is probably slower because the tires will not hook up at all. i am not worried about my transmission though one of the guys at the shop wants to rebuild and upgrade it anyway. in other words leave yours alone.
Old Jan 6, 2007 | 08:27 AM
sixvi6-camaro's Avatar
No TM on my car after the FLT tranny and stall. First thing I noticed was how quick and smooth the shifts were. No more weird noticable loss of power and "Blahhhhh" exhaust sound just before and after the shifts. From what I've read 01-02's will back off up to 30* of timing on the shifts depending on how much torque the ECM thinks the car is making during the shift. Earlier cars have a lot less timing retard in the TM Programing so it is not nearly as noticable. You could have the TM % cut in half. that would still cushion the shifts but not be soo noticable.
If you already have a small tranny problem though getting rid of the TM will seek it out and cause a failure much quicker.
Old Jan 6, 2007 | 08:56 AM
Forgot.. I had this link saved that has a real nice explanations of TM and even has Ls1Edit logs of the TM in action.
http://www.ls2.com/forums/showthread...hreadid=361225
Old Jan 6, 2007 | 09:30 AM
omcar's Avatar
i needed to delete the TM when I installed the transgo shift kit...
Old Jan 6, 2007 | 12:11 PM
Joel_SS's Avatar
If you do not want to completely remove it, you can reduce it some...
Old Jan 6, 2007 | 10:49 PM
2002LS1Z's Avatar
I've had TM deleted for quite some time (25,000 miles and now at 68,000)with no problems...yet.
Old Jan 6, 2007 | 11:15 PM
TonyGXP's Avatar
TM is overrated.. guys blow trans with it 100% no mods.. keep it cool and take it out.. heat is the killer.
