How fast can the 4L60E shift?
Old Jan 6, 2007 | 11:01 AM
Runn's Avatar
Default How fast can the 4L60E shift?
The time it takes to get from 1 to 2 for example?
Old Jan 6, 2007 | 11:54 AM
DannoWS6's Avatar
.435627 seconds
Faster than me with Jessica Alba
Seriously your question doesn't really have a exact answer, to many factors, there are shift timing tables and pressure related input that determins speed of shift as well as mechanical components at hand. Lets just say that a shift kit only car at WOT will shift fast enough to slam you back decent on the 1-2 in under a second.
Old Jan 6, 2007 | 06:21 PM
mullenh's Avatar
are you in the computer program and thinking about changing it?
Old Jan 7, 2007 | 02:48 AM
Runn's Avatar
Not now... i just interested if anyone know how fast a 4l60e can shift.
Old Jan 7, 2007 | 08:42 PM
02 BLK WS6's Avatar
2-3 is the slowest shift. Most moving parts involved in a shift.
Old Jan 8, 2007 | 10:10 AM
VORTECFCAR's Avatar
about .12 seconds
Any faster and you get overlap on a stock trans.
Old Jan 8, 2007 | 02:13 PM
Runn's Avatar
Originally Posted by VORTECFCAR
about .12 seconds
Is that a fact?
Old Jan 8, 2007 | 02:19 PM
PBA's Avatar
PBA
On the 1-2 WOT shift, the shift time of 2-4 tenths is considered ok. It depends on the apply servo being used, band material, feed hole in the separator plate, the accumulation setup, main boost valve, size of torque converter, stall of the torque converter, engine modifications, etc. There is not any overlap on the 1-2 shift, just the 2-3 shift. 2 tenths is about as quick as you would ever want, the shift should be quick, and not overly firm.
ChocoTaco369's Avatar
Tech Resident
lol this post is funny.
the correct answer is faster than any human could ever shift a car with a manual transmission, making the 4L60E a better choice for drag racing.
Old Jan 8, 2007 | 02:37 PM
Runn's Avatar
I am just curious ...and just comparing the 4L60E with other auto gearboxes for fun.
Old Jan 8, 2007 | 02:40 PM
landstuhltaylor's Avatar
if it can really do it in .12, thats near F1 territory
Old Jan 8, 2007 | 02:42 PM
Tech Resident
it shifts pretty darn quick IMO. it's a little laggy at low RPM's but when you get over 3,000+ rpm's and start really throwing power down, even the stock 4L60E's shift pretty quick. now, i hear torque management slows them down a lot, so if you delete that, it'll shift even quicker. put in a shift kit and it'll be even faster yet.
are you looking for the stock shift speeds w/torque management, without torque management or the fastest a 4L60E can shift modded?
Old Jan 8, 2007 | 02:59 PM
Runn's Avatar
The fastest thing there is
Stock without torque would be fun to have the numbers on.
0.12 sounds really fast compared to a F430 that shifts in 0.15 (totally different gearbox i know)
