Auto 2-3 shift bouncing off rev liter at WOT
Old Aug 18, 2002 | 10:21 PM
Fusion's Avatar
Default Auto 2-3 shift bouncing off rev liter at WOT
Guys,
At WOT my A4 is bouncing off the rev limiter for the 2-3 shift. It is doing it all the time now. What could be the problem? It seems to be shifting fine at all other throttle positions. I checked the fluid level. It is fine. The color seems to be more of a brownish color than cherry red though. A buddy of mine suggested a problem with the valve body. Thanks
Mike
Old Aug 19, 2002 | 04:23 AM
Damian's Avatar
LSX Mechanic
Default Re: Auto 2-3 shift bouncing off rev liter at WOT
Usually thats a tuning issue. Do you have a Hypertech programmer by any chance? If not, that may be a cheap solution instead of getting a dealer to reflash the PCM.
Old Aug 19, 2002 | 07:25 AM
Ragtop 99's Avatar
do your free mods include ported MAF ends? If yes, try a set of stockers.
How many miles on the tranny and are they tough miles?
Old Aug 19, 2002 | 06:21 PM
Fusion's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>do your free mods include ported MAF ends? If yes, try a set of stockers.
How many miles on the tranny and are they tough miles?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes...I cut out the metal in the MAF ends. 57k miles, not driven too hard.
Old Aug 19, 2002 | 06:53 PM
h53speed's Avatar
It's your MAF ends. I had the same problem... Tuned it out using the hpp3 by raising the shift point MPH by 4 and raising the rev limit to 6300.
Old Aug 19, 2002 | 09:02 PM
Fusion's Avatar
I figured you would have to LOWER the shift point. Will 6300 rpm risk pushrod bending?
Old Aug 20, 2002 | 08:19 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I had to move my limiter to 6300 because of the ST3500. It's been there 2 months with no apparent problems. IMO you're fairly safe there.
Old Aug 20, 2002 | 07:22 PM
h53speed's Avatar
By raising the shift point MPH you are also raising the amount of revolutions allowed for that shift. I think that its around 56 rpms for each MPH on the 2-3 shift. That would allow for ~6500 max rpms for that shift. Keeps you from hitting the limiter at least.
Old Aug 20, 2002 | 07:27 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Guys read his first post better.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I checked the fluid level. It is fine. The color seems to be more of a brownish color than cherry red though.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Goodbye 3-4 clutch pack. The famous crappy 4l60e.
Tim
Old Aug 20, 2002 | 07:42 PM
gwj's Avatar
gwj
When I check the fluid level, it doesn't look "cherry red"; when I pull the pan it does. Last (3rd) fluid change a couple weeks ago @ ~55K the bottom of the pan was coated black. TC clutch glaze? Dunno but it still works fine. (fingers crossed)
