4l60e Trans problem after shift kit and high stall conveter installed
Old Jan 25, 2007 | 07:09 PM
black99ls1's Avatar
Default 4l60e Trans problem after shift kit and high stall conveter installed
i installed a trans go shift kit with servos. i followed the direction and made sure that the bolts in the valve body are in the correct loction, i checked myself many times. i made sure that the tail shaft could turn both ways when in neutral. When i installed the coverter all the way in i cant turn the converter. so my question is why do you think i cant turn the converter to line up with the flexplate bolts? I thank you for any help you can give me!
Old Jan 25, 2007 | 07:15 PM
performabuilt's Avatar
LS1Tech Sponsor
Do you mean with the trans not installed you cant rotate the converter , it wont turn , did you disassemble the pump?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 25, 2007 | 07:18 PM
black99ls1's Avatar
nope i sure didn't
Old Jan 25, 2007 | 07:19 PM
LS1Tech Sponsor
but the trans is or is not in car assuming you removed the trans ?
__________________
Call 888-744-6542
Old Jan 25, 2007 | 07:20 PM
black99ls1's Avatar
is not in the car
Old Jan 25, 2007 | 07:21 PM
LS1Tech Sponsor
Sorry of course you removed the trans if you put a converter in what i mean is when you insert the converter it just locks down ?
__________________
Call 888-744-6542
Old Jan 25, 2007 | 07:22 PM
black99ls1's Avatar
i thought i had it all the way down and i try to install it. while i was trying to intstall the trans. i realized that there was something wrong so i pulled it back out of the car and got the converter all the way down the it wouldn't turn.
Old Jan 25, 2007 | 07:23 PM
black99ls1's Avatar
yea it just locks down and will not move either way
black99ls1's Avatar
the converter is a yank pt4000
Old Jan 25, 2007 | 07:28 PM
LS1Tech Sponsor
well if you haven't pulled the pump or disassembled it then you have and issue with the converter slide the old one back in and see if it will turn
__________________
Call 888-744-6542
Old Jan 25, 2007 | 07:38 PM
LS1Tech Sponsor
let me know what happens
__________________
Call 888-744-6542
Old Jan 25, 2007 | 07:39 PM
black99ls1's Avatar
do you think i mess up pump when i try to install it the first time. this trans and converter has been sitting in my shop for about 6 months
Old Jan 25, 2007 | 07:41 PM
black99ls1's Avatar
i just went out there i got the convert to turn. it was really hard at first then it loosen up after i turned it back on forth for a little bit
Old Jan 25, 2007 | 07:55 PM
LS1Tech Sponsor
Ok well still worries me some i would turn it several times and make double sure
__________________
Call 888-744-6542
