Trans Temp gauge Help
Old Feb 1, 2007 | 07:11 PM
BubaGumpShrimp's Avatar
well i do agree on the stock water gague being an idiot light, i was more talking about moving the sender to the hottest place in the water path. In any event a temp gauge is better than no gauge.
Old Feb 1, 2007 | 07:14 PM
99Hawk262's Avatar
My tuner also read my trans temp after numerous WOT runs and it wasn't close to what my gauge showed (~22 degrees difference). Makes me even happier that I mounted it where I did. Just sharing my experience, take it for what it's worth.
Old Feb 3, 2007 | 01:30 PM
Matt D's Avatar
Retired Street Racer
I have an Aeroforce guage that plugs in to the PCM and reads trans temp and coolant temp. (Just like you would with Autotap & HP Tuners)
It is a pretty good investment and reads about 20 other parameters.
Old Feb 3, 2007 | 01:40 PM
Tonner's Avatar
Ive just been sittin on the fence here thinkin why dont yas read it from the pcm, Aeroforce style , and bingo here is the man with the right plan ,, lol.
Old Feb 3, 2007 | 02:49 PM
DanZ28's Avatar
Did a search and here are some direct quotes from the Pro's:
Originally Posted by Vince @ FLT
When you mount the sensor in the pressure port you are reading temps of the main line pressure, meaning pump pressure. You also have the tc right there and when stalling it gives off tons of heat that transfers directly into the pump. I've always been taught that the sensor needs to be mounted in the return cooler line or in the oil pan. In these locations you will get a much more accurate reading of oil temp. The reason is because the temp of the oil is fairly close to over all trans temp. Cooler oil is lube oil pressure/flow and this is what is used to cool and lube the parts. The temp of that oil is much closer to accual trans temp. I hope this makes sense. I do know that main line pressure tap is the easy way to go but IMO not correct.
Originally Posted by Rock-On
The pressure port quit simply is a dead end (meaning you don't have any fliud flow) It'll only get as hot as the case gets which is in no way the temp of the trans fliud. Putting the Tap into the cooler line gives you the true temp right out of the converter, which in my humble opinon is the temp you wanna monitor. However there are those who choose to install the tap into the lube circuit (upper or return oil), this gives you the temp of the lube (cooled) oil. Putting them in the pan just makes a mess/however is a better place than the pressure port....but still not as true as the cooler/ lube return lines...hope this helps Dave
pcm reads it out of the pan....on the manifold switch body.Its mounted to the valve body....we've seen some of the gages read 40 degrees difference..IMHO they aren't very accurate, pretty generic.....Hope this helps...Dave
Dan
Old Feb 3, 2007 | 05:28 PM
99Hawk262's Avatar
Wow, that's good info....and what I've been trying to say.
Old Feb 3, 2007 | 05:34 PM
Hell'sChariot's Avatar
So after the cooler is where the sending unit should go?
Old Feb 3, 2007 | 05:45 PM
99Hawk262's Avatar
Before the cooler. Right after it exits the tranny on its way to the cooler. That is an ideal spot to put it.
Old Feb 3, 2007 | 10:49 PM
DanZ28's Avatar
According to the quote I posted above, the cooler return line is the ideal place. I use the pan myself..
Dan
Old Feb 3, 2007 | 10:55 PM
DanZ28's Avatar
Good ole search feature . I remember the thread from when I was installing the trans temp guage myself.
Old Feb 8, 2007 | 01:17 PM
DYING BREED's Avatar
thanks for the help guys, the install went great, pics to follow in a few, as soon as i find my card reader..... that was super easy...
Old Feb 8, 2007 | 05:43 PM
  #32
meat's Avatar
but did you move the sender? thats what those guys are trying to say
Old Feb 15, 2007 | 12:14 PM
  #33
heres my pics, i also made a copy of how to do the install if anyone needs
http://i47.photobucket.com/albums/f179/joer09/Picture021-1.jpg
http://i47.photobucket.com/albums/f179/joer09/Picture023.jpg
Old Feb 15, 2007 | 12:15 PM
  #34
sorry thy this
Old Feb 15, 2007 | 01:38 PM
  #35
12secSS's Avatar
I prefer this one myself. Very easily read at night, since it is an LED backlit gauge.
Old Feb 15, 2007 | 02:14 PM
  #36
thunderstruck's Avatar
for those of you with the sender in the line going to the cooler, what kind of fitting are you using ?
Old Feb 15, 2007 | 05:04 PM
  #37
jorgez28's Avatar
ok so does any one have directions for mounting and putting the sending unit on the cooler line?
Old Feb 16, 2007 | 08:49 PM
  #38
99Hawk262's Avatar
This is all the info/pictures I have. It's been a while since I did this, so I don't remember the size or anything, I just took the sending unit to Lowe's and matched it with a brass T-fitting. One side is bigger because the factory rubber line is smaller than the 3/8" line supplied with the cooler. The rest is pretty self-explanatory. Just have to remember to run the proper ground wires. The instructions are a little vague that come with the temp gauge. Hope this helps.
Old Feb 16, 2007 | 11:03 PM
  #39
Tonner's Avatar
As said somewhere above, the pcm reads from a stupid place, it takes the pcm a while to read the temp changes,, i.e heat it up by stalling up and the temp rises some 30 secs later. using the aeroforce gauge.
Old Feb 16, 2007 | 11:21 PM
  #40
jorgez28's Avatar
thanks 99hawk262 do you have pic from inside the car and where you mounted it
