Just bought 99T/A A4, What gear do I have?
Old Aug 28, 2002 | 11:00 PM
RickZZ's Avatar
Default Just bought 99T/A A4, What gear do I have?
Hi, how can I tell which gear I have? I have the 150MPH spedo, in the old days(1995-96) that told you you had the 3.23's. Is it still same on the 99's? Or do you have to look on the door codes? If so what codes do I look for? Any help would be greatly appreciated! Thanks,
Rick
Old Aug 28, 2002 | 11:59 PM
RTCamaroSS's Avatar
Default Re: Just bought 99T/A A4, What gear do I have?
Automatic cars have 3.23's, Manuals have 3.42's, i think some auto's had 2.73's or something like that, but they arent as common. Check door codes, im not 100% what the codes are...
<small>[ August 29, 2002, 12:07 AM: Message edited by: RTCamaroSS ]</small>
Old Aug 29, 2002 | 12:03 AM
TomQ's Avatar
mine is 2k1 and i have 2.73, don't know about 99
yes, there is a code on the door, i don't rememebr which one
ttt
Old Aug 29, 2002 | 12:19 AM
ZEIK 383's Avatar
Rick, here is what you are looking for: Code GU2 designates 2.73 gears, and if you see Code GU5, you have 3.23 gears. Look inside your glove box for these codes; not your door.
Old Aug 29, 2002 | 01:01 AM
Pete2k_Z28's Avatar
If for some reason the codes are missing, here's another way to tell. 2.73 cars get a steel driveshaft, and 3.23 cars get an aluminum peice. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Pete
Old Aug 29, 2002 | 09:26 AM
Paul F's Avatar
The codes are on your DRIVER DOOR on a white square sticker, not in the glove box....
Paul
Old Aug 29, 2002 | 10:31 AM
It'llrun's Avatar
Does anyone know which gears came in each different year model 4th gen A4's? I've heard of 2.73's, 3.23's and 3.42's. Nobody seems to know for sure (with good reason) and I'm curious.
Old Aug 29, 2002 | 10:42 AM
ZEIK 383's Avatar
Paul, you're right about the location of the codes. I was thinking of the LT1 cars. My bad.
Old Aug 29, 2002 | 10:51 AM
ZEIK 383's Avatar
I think that all A4's came from the factory with 2.73 gears unless you opted for the performance axle package; then you get 3.23 gears. I've never seen a factory 3.42 automatic.
Old Aug 29, 2002 | 10:59 AM
Blue98TA's Avatar
RPO code for a 2.73 rear axle is GU2. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Aug 29, 2002 | 11:16 AM
It'llrun's Avatar
I just checked on Chevy's website. Problem is (I'm sure you all know), that I can only get the info for 2002 models. Anyway, they list 3.23 and 3.42 as options and 3.08 as standard. The 3.42 is only an option for non Z/28's if I read it correctly. 2.73's aren't listed. But again, it's only 1 year model. Now I wonder when they stopped using that gear.
