th400/ get trans brake?
Old Aug 29, 2002 | 11:13 AM
highgmc's Avatar
Default th400/ get trans brake?
sorry for all the th400 questions but I am ordering it soon and wat to get all the corect options.
I am leaning toward their manual/auto (supposedly somehow works as both)
I have 3.73 gears, will be running a fresh bottom end(je pistons/rods/etc) mti stage 2 heads, c2 cam and tnt 100 shot. thinking about a yank 3800 converter...
should I get a trans brake?
will it only work with a full manual valvebody?
anyone do alot of street driving with a manual valvebody?
Old Aug 29, 2002 | 06:47 PM
john butler's Avatar
Default Re: th400/ get trans brake?
a trans brake is a new valve body, and on the 400 it is a full manual, reverse shift pattern. if you want the best perfomace the t-brake is the only way to go. my car is set on so that when the tras brake goes off the nitrous comes on. it feels like you got rear ended by a cement truck!
Old Aug 29, 2002 | 07:31 PM
highgmc's Avatar
well then cement truck it is!!!
do you just shift by a shift light?
drive much on the street? annoying or get used to it?
ordering tomorrow!
Old Aug 29, 2002 | 08:02 PM
LS1derfull's Avatar
How about a parts list and sources for complete T400 into fbody swap? Anyone? TIA
Old Aug 29, 2002 | 08:06 PM
highgmc's Avatar
my choices are
th400 www.rosslertrans.com
converter YANK! pt 3800?
dipstick madman! (VERY NICE GUY!)
crossmember BMR
poly th400 trans mount www.summitracing.com
shift light www.summitracing.com
shifter www.summitracing.com
Old Aug 30, 2002 | 05:45 AM
LS1derfull's Avatar
Thanks, does BMR crossmember have provisions for rearend torque arm?What changes in driveshaft length also? Any details appreciated.
Old Aug 30, 2002 | 06:23 AM
jswhite's Avatar
You better have a 12 bolt or 9 inch rear if your going to run a transbrake or you will destoy the 7.5 very quickly. <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Aug 30, 2002 | 06:38 AM
highgmc's Avatar
yep! moser 12 bolt ordering trans tonight WITH trans brake!!!
hopefully I can get used to the manual vb on the street...
Old Aug 30, 2002 | 09:33 AM
Patrick G's Avatar
LS1 Tech Administrator
Terry,
Don't forget to get some sort of tranny tricker device. This will fool your pcm into thinking the transmission is still hooked up. If you don't run one, you may run into problems.
Patrick
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 30, 2002 | 11:06 AM
highgmc's Avatar
I will be needing my computer reprogrammed when I get my motor in anyway, can't MTI just program out the tranny codes with edit?
Old Aug 30, 2002 | 11:41 AM
Patrick G's Avatar
Hopefully so. Give them a call and ask Jayson what he does.
__________________
Old Aug 30, 2002 | 06:35 PM
SILVER BULLET's Avatar
I recently did a TH400 and I love it. I decided not to do the t-brake at first because of current traction issues. I wanted that under control first. I will get it in the next several months. They are definitely harder on the tranny and affect streetability if I recall correctly.
The manual valvebody I got used to on the street, you just have to be careful what shops you take the car to if you aren't already.
At this point I have no speedometer, we are looking for a way to make it work correctly.
What have others done about the speedo after installing a TH400?
Dave
Old Aug 30, 2002 | 08:29 PM
highgmc's Avatar
silver,
I am glad to hear you can get used to it! what is a rci blanket?
Old Aug 31, 2002 | 12:52 AM
The company is RCI and it is a blanket that covers the transmission. It is a rule for NHRA I believe to have a scatter shield over the tranny in case it blows up into small pieces. I bought a shield, but it didn't fit right. Instead I bought a blanket to protect me from transmission fragments if the tranny breaks.
Just thought I would play it safe
