Tranny temp guage install Qs.
Old Aug 29, 2002 | 10:17 PM
STS99TA's Avatar
Default Tranny temp guage install Qs.
Where is the easiest and most effective place to install the sending unit?
Does anyone have a write up on how to do it. I have the autometer gauge with the dual pod.
This is for a 99 A4
Thanks
STEVE
Old Aug 29, 2002 | 11:53 PM
1BDLS1's Avatar
Default Re: Tranny temp guage install Qs.
What I did was order a little T type thing from jegs( its in the gauge section). It goes in the oil line of the trans and then the sendind unit screws into it. I didn't install it yet but it seems pretty easy.
Old Aug 30, 2002 | 12:22 AM
Hugger's Avatar
Mike at Yank advised me not to install one in the trans pan since it would not give a very accurate reading of the trans temp. I would be interested to know the part # for the T-fitting from the above post. Was it hard to install?
-Josh
Old Aug 30, 2002 | 12:55 AM
35th SS's Avatar
so where would you install the sending unit?waiting to install mine soon.would appreciate the info.thanks. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 30, 2002 | 10:06 AM
1BDLS1's Avatar
The part # is 105-2286 its $35.99. The two ends connect to the trans line so that the oil will flow through it. Then the sending unit screws into the other whole. All thats left then is to wire it in. I have not installed it yet but it seems pretty easy.
Any one know how to install an oil pressure gauge?
Old Aug 30, 2002 | 09:20 PM
Dave Carney's Avatar
I did extensive testing of my autometer guage with sending unit mounted in the pan versus what Autotap showed as the trans temp. The Autotap number was always 10 or 11 degrees higher...Always..... So that's the difference, 10 degrees, pretty easy math to do in your head.
Old Aug 31, 2002 | 06:14 AM
35th SS's Avatar
thanks for the info.will look into it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
