stall or gears
Old Feb 15, 2007 | 07:42 PM
2002camaross35th's Avatar
Default stall or gears
I have a 2005 corvette. I have a lg pro long headers. I also have a vararam.
I recently installed a t-rex cam . My question is I'm intrested in buying a stall or gears. What would benefit my car more to be quicker in the quarter mile?
Old Feb 15, 2007 | 08:12 PM
RoWDyWS6's Avatar
im guessn a stall is quicker, but im goin with a gears 1st..
Old Feb 15, 2007 | 08:24 PM
iroc85blu's Avatar
stall from what ive heard can drop u a half second in the quarter. I did gears (cause i broke mine) and stepped to 3.73's from 3.23's. It feels a touch quicker by my guess would be only a tenth or two in the quarter
Old Feb 16, 2007 | 12:24 AM
sweetness's Avatar
I think a stall should be put with that cam or any good size cam for that matter
Old Feb 17, 2007 | 10:41 AM
sickws698's Avatar
id say get a geear first
Old Feb 17, 2007 | 10:53 AM
02 z/28's Avatar
stall,stall,stall
Old Feb 17, 2007 | 11:34 AM
TT632's Avatar
One of the magazines did a comparison on stall vs. gears a few years ago. If I remember right: They varied different stall speeds while keeping the gear constant, then they varied the gears while keeping the stall constant.
Outcome was very similar for 60 ft, 1/4 and 1/8 mile.
Personally, I would go with a good high stall converter with lock-up. This will give you the best of both worlds- get into the rpm range where your making power when your nailing it off the line and maintain lock up when cruising. One of the few mods that will make you quicker and not lose mileage.
With gears only you will have to contend with the higher rpm range on the high way.
Old Feb 17, 2007 | 12:37 PM
sweetc6's Avatar
I have a 2005 c6 z51 and I have 373 gears and a vigalante 3200 converter and these 2 mods are the best mods I have put on any vechicle.Do them both because it is cheaper labour wise why everything is open up.GARY
Old Feb 17, 2007 | 07:29 PM
RoWDyWS6's Avatar
stalls are expensive... pretty sure thier worth it but gears are cheaper...now i think to myself, 373s or 410s?...
Old Feb 17, 2007 | 07:34 PM
bene's Avatar
Trunion King
save your money and do both. I did 3.42s swap from 2.73s and Yank 3500. Of course there is also tune involved.
Old Feb 17, 2007 | 07:36 PM
02sleeperz28's Avatar
I agree with above^. do both make sure your stall and gears match accordingly. good luck
Old Feb 17, 2007 | 09:55 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I did both at the same time. However, if i had to pick one then it would be a Yank converter.
Old Feb 17, 2007 | 11:12 PM
Magnet's Avatar
converter hands down no comparison
Old Feb 23, 2007 | 06:32 AM
theslow00's Avatar
im doing gears first do to the breaking of my rear end lol going from 273 to 342 ill post and let you no the time diff!!
Old Feb 23, 2007 | 06:54 AM
staringback05's Avatar
stall would prolly be the best choice first off
Old Feb 23, 2007 | 06:07 PM
Sunset'01Z's Avatar
def stall tc first..
after a stall tc, changing ratios will usually only net you about .1 and 1mph in the 1/4 no matter what ratio u go to, because a stall gets you in your powerband and keeps you there.
Old Feb 23, 2007 | 06:19 PM
brady346's Avatar
Stall for sure. Me and a friend had cars that were almost alike but his had a ton more mods and my stalled car would WALK his car with gears and more bolt ons. 3400 rpm stall ftw.
Old Feb 23, 2007 | 11:50 PM
presto_z's Avatar
a stall no doubt. you will see better gains from a stall and it will help your cam get in its power range sooner...
or just do both at the same time like me and then you dont have to worry about which one to do first
