Big Problem!
Old Mar 7, 2007 | 03:14 PM
fbodyfreek's Avatar
Default Big Problem!
okay, i'm gonna explain this the best i can:
i have a 4L60E. i noticed that the car was acting funny about a week ago, but i didn't think much of it. well today as i was leaving school it messed up big time.
i turned right out of the parking lot. as soon as i straightened up i tried to accelerate, but the car didn't move. the rpm's would go up but the car was out of gear, but the shifter was definitely in drive. i kept feathering the throttle, but it didn't work. it finally caught as i turned into the gas station.
from a stop it will not shift until about 3500rpms. after i get into second gear it's like it's in "race mode" though, cuz then i can tap the gas and it wants to sit down and go. i'm not even sure if i'm starting in first gear because the feeling is similar to when you start a manual in too high of a gear... it's sluggish. when it finally shifts it jerks harshly into gear too. i haven't tried it at higher speeds yet because i'm afraid to. is this a bad torque converter? low fluids? or something else?
i will admit that i've been driving the car hard lately, mostly racing from rolls, in which i start in second gear. but i really need help. any ideas? thank you.
Old Mar 7, 2007 | 03:24 PM
performabuilt's Avatar
LS1Tech Sponsor
Check fluild level running in park , The clear codes , Then drive again and see what you get ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 7, 2007 | 03:34 PM
fbodyfreek's Avatar
it makes the "HOT" mark, but it has bubbles, is this normal? sorry, i'm a newbie... what would the clear codes be? the "service" light isn't on.
Old Mar 7, 2007 | 03:45 PM
LS1Tech Sponsor
What does the fuild look like and smell like and if theres no ses light dont wory about codes right now
__________________
Call 888-744-6542
Old Mar 7, 2007 | 03:47 PM
fbodyfreek's Avatar
i've gotta go to work, but i'll get back to you later tonight... but i'll have to smell it and it doesn't look very thick. almost like water. i'll take the truck for now. any more ideas? thanks for your help.
OldSchoolFormula's Avatar
check the vss signal. My trans acted like that with it isconnected.
Old Mar 8, 2007 | 04:12 PM
fbodyfreek's Avatar
where's that at?
Old Mar 8, 2007 | 05:56 PM
The VSS sensor is on the side of the transmission. Does your speedometer work okay?
Old Mar 8, 2007 | 07:58 PM
fbodyfreek's Avatar
yep, it's fine. i'm getting everything flushed and the fluids replaced this weekend. i'm hoping that will fix it.
Old Mar 10, 2007 | 12:39 AM
CODE4LS1's Avatar
Sounds like the shift solenoids are bad....I would go ahead and replace both while you have the pan off.
Old Mar 11, 2007 | 10:46 PM
marooncamaroz28's Avatar
How easy is it to change out the solenoids?
Old Mar 11, 2007 | 11:05 PM
CODE4LS1's Avatar
Not at all, just need a screwdriver to poop them off......theyre located on the rear of the trans on the valve body
