Electrical Connection On TH400? Pic...
Does anyone know what this connection is for?
"P" plug with one wire???
and
"B" bolt there, can I remove the bolt and install a temp sender there?
and
LS1Tech Sponsor
yes you can put the temp sensor there it isnt the most acurate place though ,
as for the switchits kick down , passing gear , when power is applied in cars that had it originally it would cause the car to kick down to second and hold gears longer in drive
__________________
